Receiving GStat messages in GladeVCPs
- HansU
- Thank you received: 217
19 Sep 2024 02:49 - 19 Sep 2024 02:51 #310427
by HansU
Receiving GStat messages in GladeVCPs was created by HansU
I want to use some GStat messages in a Glade VCP (in gmoccapy), but it seems that not all messages seem to work there.
If I take the example from linuxcnc.org/docs/2.9/html/gui/gstat.htm...tension_code_pattern everything works as expected.
Then I added
The result is that I only get the message resp. signal when a new file is loaded, not on a reload.
But if I add this signal in the gmoccapy code directly, I get an event on every reload.
Furthermore the signal "graphics-gcode-properties" works fine inside gmoccapy, but in a VCP I don't get the message at all?
Any ideas about this behaviour?
Then I added
GSTAT.connect("file-loaded", self.file_loaded)
def file_loaded(self, obj, data):
print("FILE LOADED:", data)
Last edit: 19 Sep 2024 02:51 by HansU.
- Thank you received: 4659
28 Sep 2024 04:07 #310950
Replied by andypugh on topic Receiving GStat messages in GladeVCPs
This sounds like a question for Chris, and might do better on the dev mailing list.
- Thank you received: 2181
28 Sep 2024 07:58 #310975
Replied by cmorley on topic Receiving GStat messages in GladeVCPs
From hal_glib.py:
Specifically ignores loading with the same filename (reloading)
I'll have to dig a bit to comment about gcode-properties - just off to work
Chris
# file changed
file_old = old.get('file', None)
file_new = self.old['file']
if file_new != file_old:
# if interpreter is reading or waiting, the new file
# is a remap procedure, with the following test we
# partly avoid emitting a signal in that case, which would cause
# a reload of the preview and sourceview widgets. A signal could
# still be emitted if aborting a program shortly after it ran an
# external file subroutine, but that is fixed by not updating the
# file name if call level != 0 in the merge() function above.
# do avoid that a signal is emitted in that case, causing
if self.stat.interp_state == linuxcnc.INTERP_IDLE:
self.emit('file-loaded', file_new)Specifically ignores loading with the same filename (reloading)
Chris
28 Sep 2024 09:20 #310979
Thinking more about it...
If your gladevcp panel does not have gremlin object in it, you will not get gcode properties generated in that pythons context.
29 Sep 2024 21:33 #311051
This stems from the short coming of linuxcnc's status process or maybe better a lack of development of GUI communication process.
Gstat is an intermediate communication process between linuxcnc status and the GUi, that is easily modified/extended for the GUI needs.
If a single Gstat instance could be used/communicated to by all GUIs - that would be much better. You can kind of do this by using ZMQ etc to broadcast some data. I don't know if using ZMQ for all linuxcnc status would be fast enough. I was toying with adding it to HALUI as a test but again only some messages.
Or if linuxcnc's status was more easily extended and allowed GUIs to send messages that would be better too.
Chris
This is mostly beyond my programming skills.
Chris
- HansU
13 Nov 2024 13:20 #314396
by HansU
Sorry for my late reply but I was expecting to get an email notification...
In detail, I have this VCP:
and I have a user command file in gmoccapy running with
When first open a file, I get this output:
On reload I get only the messages from the user command file:
When staring the program, I get the line-changes from both:
Replied by HansU on topic Receiving GStat messages in GladeVCPs
Yes and I was pretty sure he will read thisThis sounds like a question for Chris, and might do better on the dev mailing list.
Why do you think so? It's just a textual message giving some information about the G-code.From hal_glib.py:
Okay but why do I get a signal though when I run it as a user command file?From hal_glib.py:
#!/usr/bin/env python3
from hal_glib import GStat
GSTAT = GStat()
class HandlerClass:
def __init__(self, halcomp, builder, useropts):
self.builder = builder
GSTAT.connect("graphics-gcode-properties", self.gcode_properties)
GSTAT.connect("line-changed", self.line_changed)
def gcode_properties(self, obj, data):
print("[VCP] G-code properties:", data["name"], data["size"].replace("\n",", "))
print("[VCP] File loaded:", data)
def line_changed(self, obj, data):
print("[VCP] Line changed:", data)
def get_handlers(halcomp,builder,useropts):
return [HandlerClass(halcomp,builder,useropts)]and I have a user command file in gmoccapy running with
USER_COMMAND_FILE = custom_init.pydef gcode_properties(obj, data, widgets):
print("[rc] G-code properties:", data["name"], data["size"].replace("\n",", "))
def file_loaded(obj, data):
print("[rc] File loaded:", data)
def line_changed(obj, data, widgets):
print("[rc] Line changed:", data)
hal_glib.GStat().connect("graphics-gcode-properties", gcode_properties, self.widgets)
hal_glib.GStat().connect("line-changed", line_changed, self.widgets)
hal_glib.GStat().connect("file-loaded", file_loaded)When first open a file, I get this output:
[VCP] File loaded: /home/cnc/linuxcnc/nc_files/3D_Chips.ngc
[rc] G-code properties: 3D_Chips.ngc 200509 bytes, 4714 gcode lines
[rc] File loaded: /home/cnc/linuxcnc/nc_files/3D_Chips.ngcOn reload I get only the messages from the user command file:
[rc] File loaded: /home/cnc/linuxcnc/nc_files/3D_Chips.ngcWhen staring the program, I get the line-changes from both:
[VCP] Line changed: 24
[rc] Line changed: 24
[VCP] Line changed: 25
[rc] Line changed: 25
[rc] Line changed: 26
[VCP] Line changed: 26
...Please Log in or Create an account to join the conversation.
13 Nov 2024 20:37 #314414
Gcode properties are generated in Gremlin and then sent out using Gstat messages to whomever is connected in that GSTAT python instance context.
line change messages come from linuxcnc status, which is available in every GSTAT python instance.
So if your vcp has no gremlin then it gets no gcode properties message.
'hal_glib.GStat()' is an unusual way to create a callback. usually GStat is instantiated once with a self.variable_name = GStat().
I have a hunch that is why you get a 'file-changed' message on reload, but would have to test to confirm.
Chris
Chris
- HansU
15 Nov 2024 18:14 #314580
by HansU
If I add a Gremlin object to the Glade file, then I get the G-code properties, nice. Thanks for that hint
I am looking forward to your idea..
Chris
Moderators: HansU
Time to create page: 0.779 seconds
