Modifying qtdragon screen
- Daroum
04 Aug 2025 04:13 #332802
by Daroum
Modifying qtdragon screen was created by Daroum
Hello everyone
I want to create a new screen for a machine that i am working on
Qtdragon seems ideal for me but i need to modify it by deleting some sections that i don't need and adding other sections and buttons i already installed glade and also qt creator.
The board that am using ( mesa 7i76e) is in the machine and it's a bit far from me i couldn't use it for now so i can't create a project using my board configuration
So i need to create a modified qtdragon template or modifying the .ui file of the qtdragon template
When i create sim project based on qtdragon i couldn't find where i should make the modifications (.ui file doesn't exist in my project directory)
Anyone has an idea how to do that ?
Thanks in advance
Thanks in advance
- MarkoPolo
- Thank you received: 92
04 Aug 2025 15:27 #332844
by MarkoPolo
Replied by MarkoPolo on topic Modifying qtdragon screen
It would be better to ask this question in the qtvcp section.
Qtdragon doesn't use Glade. You won't need Qt Creator either.
To modify the .ui file, install Qt Designer.
Marek
Marek
Moderators: HansU
Time to create page: 0.338 seconds
