Zero the DRO
1 year 2 weeks ago - 1 year 2 weeks ago #336352 by richcolvin
Zero the DRO was created by richcolvin
I want to put a button on the Glade panel which will zero out the DRO.  I don't want to HOME the axis as I want it to be good where it is.
On the panel, I am currently displaying the DRO value from position-fb:
HAL file:
net x-pos-fb    => pid.x.feedback
net x-pos-fb   <=  hm2_7i92.0.stepgen.02.position.fb
net x-pos-fb   => joint.0.motor-pos-fb
PostGUI HAL file:
net x-pos-fb    => gladevcp.X_DRO             This is what gets displayed
I am assuming that I need to add a HAL button to GladeVCP and then call a function in the handler python program.
Within that function, how do I write a 0 to this?
Last edit: 1 year 2 weeks ago by richcolvin.
1 year 2 weeks ago #336490 by Todd Zuercher
Replied by Todd Zuercher on topic Zero the DRO
Use an mdi command to issue the appropriate G10 command.
1 year 2 weeks ago #336494 by cmorley
Replied by cmorley on topic Zero the DRO
Have you set this in the TRAJ section of the INI?
NO_FORCE_HOMING = 1
linuxcnc.org/docs/devel/html/config/ini-...tml#sub:ini:sec:traj
Then you should be able to use the normal way to zero the axis.
But you lose the safety pf soft limits with no fixed homing spot.
Moderators: HansU
Time to create page: 0.182 seconds
