Reading and writing to Parameter Variables?
  • Todd Zuercher
  • Todd Zuercher's Avatar Topic Author
  • Platinum Member
  • Platinum Member
18 Jun 2026 04:44 #347145 by Todd Zuercher
Reading and writing to Parameter Variables? was created by Todd Zuercher
I would like to set up a GladeVCP tab (in Axis) that displays and can set the values for a range G-code numbered parameter variables, similar to how most industrial control interfaces have.  I tried to use AI to write the handler file, but that is failing for me.  I used Glade to make the tab screen and that looks good and opens in the tab, it just doesn't do anything yet.  When running Linuxcnc from the terminal I'm not seeing any messages that are helping me see what is wrong.  Here are the glade and py files I have so far.
File Name: variables.py
File Size:1 KB
File Name: variables.glade
File Size:32 KB
18 Jun 2026 07:41 - 18 Jun 2026 08:22 #347147 by Aciera
Replied by Aciera on topic Reading and writing to Parameter Variables?
1. Are you sure you are actually loading 'variables.py' along with the 'variables.glade' in the ini file entry?
2. This method of reading the initial parameter values is nonsense as there is no access to the parameter values from the status channel:
# Set initial value from LinuxCNC parameters
self.s.poll()
spin.set_value(self.s.settings)
see linuxcnc.org/docs/html/config/python-interface.html for information on the 'settings' attribute.
Some thoughts on this:
a. The parameter range you are trying to read is volatile so they will all be Zero on start up. See linuxcnc.org/docs/stable/html/gcode/over...:overview-parameters
b. The only way to get the current value of any parameter is to read the value through an MDI command and grab the response.
c. Because of (b) there is no way I know of to actually query the state of a parameter while a gcode program is executing. Which implies that you would need to have something like a 'Refresh' button to read the current values of those parameters if they were changed by the execution of a gcode program.
Last edit: 18 Jun 2026 08:22 by Aciera.
The following user(s) said Thank You: Todd Zuercher
18 Jun 2026 09:14 - 18 Jun 2026 12:14 #347150 by Aciera
This example code will read parameters 5200..5299 and write the values to a file 'log.txt', in a next step you would read the file and extract the values to initialize the spin boxes:
import linuxcnc
c = linuxcnc.command()
c.mode(linuxcnc.MODE_MDI)
c.wait_complete()
# write parameter values to log.txt
# file will be in the same dir as the ini
c.mdi('(LOGOPEN,log.txt)')
c.wait_complete()
for p in range(5200,5300):
    cmd = f"(LOG,{p},#{p})"
    c.mdi(cmd)
c.mdi('(LOGCLOSE)')
Last edit: 18 Jun 2026 12:14 by Aciera.
The following user(s) said Thank You: Todd Zuercher, NWE
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
18 Jun 2026 13:03 #347152 by Todd Zuercher
Replied by Todd Zuercher on topic Reading and writing to Parameter Variables?
I'm a little disappointed that there is no way to read/monitor them directly, but I was coming to that conclusion. Now to figure out the best work aroud. I'll probably end up trying to do what you suggest. Thanks for your help.
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
18 Jun 2026 16:04 #347155 by Todd Zuercher
Would there be a way for the python handler for the vcp, to call or reference to python remap script that can access the interpreter variables?  With as little python programming skill as i have this seems like it could be possible, I wouldn't know if that is completely impossible, or not any better than writing to an intermediary file.
19 Jun 2026 00:53 - 22 Jun 2026 13:40 #347159 by Aciera
The example code can be used inside a python remap and the handler could read the file with the parameter values but the remap itself would have to be called from inside the gcode program which is currently executing.
So if you wanted your parameter page to reflect changes coming from the gcode program you would need to insert the remap after every parameter assignment in the gcode.
Another way to expose parameter values is to send them to a hal pin:
'M68 E0 Q#500' will expose parameter value 500 to the hal pin 'motion.analog-out-00' which you can then connect to your gladevcp display.
Note that the M68 code would need to be called every time after the #500 parameter is changed in the gcode and every parameter will need its own analog pin.
You could create a custom G- or M-Code to handle assigning and exposing parameter values in a single line and/or use a filter script to search for parameter assignments and add the appropriate M68 code to expose it.
Last edit: 22 Jun 2026 13:40 by Aciera. Reason: Add M68 alternative
Moderators: HansU
Time to create page: 0.171 seconds
