LPT Spindel PWM Different Speed With M3 and M4
- juergen-home
- Thank you received: 5
26 Dec 2014 23:00 - 27 Dec 2014 03:12 #54309
by juergen-home
LPT Spindel PWM Different Speed With M3 and M4 was created by juergen-home
I set up my linuxcnc like in the pictures attached.
For this setup a worked with a Spindel attached with a FVD.
With commanded M3 S3000 (cw) it runs 2690 RPM.
With commanded M4 S3000 (ccw) it runs 2870 RPM.
So I checked the spindle-pwm signal with the HAL-Scope.
The pwm signal seems to be different with M3 / M4. (picture1+2)
Can somebody verify this on his own computer?
Last edit: 27 Dec 2014 03:12 by juergen-home.
- Thank you received: 5285
27 Dec 2014 00:21 #54310
Replied by PCW on topic LPT Spindel PWM Different Speed With M3 and M4
Not sure if the pwmgen offset does what you are expecting with signed PWM values
you may have to use the absolute function on the commanded spindle speed
and feed the pwmgen with only positive values (and get the dir signal from the abs comp)
The following user(s) said Thank You: juergen-home
- juergen-home
27 Dec 2014 03:09 - 27 Dec 2014 03:32 #54311
by juergen-home
Replied by juergen-home on topic LPT Spindel PWM Different Speed With M3 and M4
So I changed the hal file the way to be told. Now it's working perfect.
Same speed for M3 and M4. Thank You.
#old: with different speed for M3 and M4 (generated by stepconf wizard)
#loadrt abs count=1
#net spindle-cmd <= motion.spindle-speed-out => pwmgen.0.value
# new: for same speed M3 and M4
loadrt abs count=2
addf abs.1 servo-thread
net spindle-cmd => abs.1.in
net spindle-cmd-abs <= abs.1.out
net spindle-cmd-abs => pwmgen.0.value
addendum:
>linuxcnc.org/docs/html/man/man9/pwmgen.9.html
>loadrt pwmgen output_type=type0[,type1...]
>type 1: pwm/direction
>Two output pins, pwm and dir. The duty cycle on pwm varies as a function of the input value. dir is low for positive inputs and high for negative inputs.
There is no hint found here that negative values are not working correctly.
#loadrt abs count=1
loadrt abs count=2
addendum:
Last edit: 27 Dec 2014 03:32 by juergen-home.
Time to create page: 0.327 seconds
