dannym wrote: The .INI file contains a lot of PID-specific stuff. Is the .INI PID stuff totally ignored if the .HAL doesn't use it?
dannym wrote: Your file used trivkins, not gantrykins.
andypugh wrote: One thing to be aware of is that LinuxCNC doesn't wait for the second axis to finish homing, so you need to configure so that the final rapid to home is as short as possible or you can have one axis doing a rapid one way while the other is doing a slow search in the other.
This is, admittedly, not ideal.
