homing sensors
10 years 6 months ago #72677 by AMelvin
homing sensors was created by AMelvin
Has anyone worked with optical switches for homing? was thinking of trying them.
10 years 6 months ago #72709 by andypugh
Replied by andypugh on topic homing sensors
AMelvin wrote: Has anyone worked with optical switches for homing?
Yes, I have used them. Transmissive with flags is probably more resilient than reflective.
I have come to prefer inductive sensors buried inside the slides where contamination and damage is less likely. That works well if you have encoders with index to give a secondary super-accurate position. without encoders the optical sensors should be more accurate than proximity sensors.
The following user(s) said Thank You: AMelvin
