Current Tool-number permanent?
- terkaa
- Thank you received: 3
23 Jun 2016 10:28 - 23 Jun 2016 10:32 #76480
by terkaa
Current Tool-number permanent? was created by terkaa
How can I make current tool number permanent? So even after power down LinuxCNC knows that ie. tool number 5 is on spindle? Tool change is written as HAL component.
Tero
Tero
Last edit: 23 Jun 2016 10:32 by terkaa.
- Thank you received: 4648
23 Jun 2016 12:01 #76486
Replied by andypugh on topic Current Tool-number permanent?
A partial solution is to configure as a random toolchanger.
One of the things that RANDOM_TOOLCHANGER does is put the tool in the spindle in pocket 0. This is written to the tool-table, and so the tool is still in the spindle at re-start.
(I think this is the case, experiment with a sim config to be sure)
It seems, however, that your toolchanger is _not_ random, the tool removed from the spindle is put back in its home slot.
I don't know if it is better documented anywhere, linuxcnc.org/docs/2.7/html/config/ini-co....html#_emcio_section
I did try to make the whole system rather better a few years ago, but the work was abandoned about the time of the Machinekit split.
(read here for the system that might-have-been: wiki.linuxcnc.org/cgi-bin/wiki.pl?ToolDatabase
The obvious solution would be to write the tool-in-spindle to disc from inside your sequencer component, but that is unfortunately not possible because the realtime system does not have access to the filesystem.
One way that should be quite reliable might be to have a userspace hal component (probably written in Python) that writes the tool-in-spindle to a disk file every time it see the tool change and a start-up G-code that reads a tool-number from that component and does a G61 and G43.
This is quite a common requirement and it is rather annoying that the system doesn't have it properly built-in.
- terkaa
23 Jun 2016 20:03 #76514
by terkaa
Replied by terkaa on topic Current Tool-number permanent?
Ok,
I had to learn some Python. I just wrote handler.py for atc_panel (to show steps/status of ATC) I also wrote saving spindle tool number to file on disk there... forum.linuxcnc.org/forum/48-gladevcp/311...g-with-hal-pin#76513 it is quick and hasty but seems to work. I have to finish it tomorrow.
Tero
Tero
- terkaa
24 Jun 2016 16:46 #76583
by terkaa
Ok,
Ended up doing this:
[HALUI]
MDI_COMMAND = M61 Q#4999
MDI_COMMAND = #4999=#5400
net machine-enabled halui.mdi-command-00
net tool-change-loop halui.mdi-command-01
This seems to handle it too. Or is there any problem with this approach?
Tero
[HALUI]
Tero
24 Jun 2016 17:22 #76585
Have you checked that the MDI_COMMAND gets called when the Tool-change is inside a G-code program?
(I have a feeling it might not be)
If not, then there is an (actually slightly neater) option that ought to work. You can re-map M6 to save the parameter and then do the M6.
linuxcnc.org/docs/2.7/html/remap/remap.h...g_the_m6_replacement
I don't think you need the python prologs, just
Then a file called change.ngc that contains
REMAP = modalgroup=6 M6 ngc=changeThen a file called change.ngc that contains
#4999=#5400
M6Please Log in or Create an account to join the conversation.
- terkaa
24 Jun 2016 19:21 #76592
by terkaa
This is giving me :
emc/rs274ngc/interp_remap.cc:575: REMAP BUG=REMAP=M6 100:REMAP = REMAP=M6 modalgroup=6 ngc=toolchange
And does not seem to work....
You are correct using halui.mdi-command-01 works with manual and MDI but not with Auto mode...
Tero
This is giving me :
Tero
24 Jun 2016 19:30 #76595
Can you paste the whole error message? Looking at the code around that spot (github.com/LinuxCNC/linuxcnc/blob/master...interp_remap.cc#L572) there should be a second error message.
The docs on remap seem to say that what was proposed will work:
linuxcnc.org/docs/2.7/html/remap/remap.h...s_including_tt_m6_tt
- terkaa
24 Jun 2016 20:07 #76598
by terkaa
Hmmm... I get only:
8199 emc/rs274ngc/interp_remap.cc:575: REMAP BUG=REMAP=M6 100:REMAP = REMAP=M6 modalgroup=6 ngc=toolchange
and this (this comes at tool change):
8202 emc/rs274ngc/interp_remap.cc:575: REMAP BUG=REMAP=M6 100:REMAP = REMAP=M6 modalgroup=6 ngc=toolchange
Tero
Tero
24 Jun 2016 21:52 #76608
I have just experimented a bit, and it does seem like you need an O<change> SUB and O<change> ENDSUB in the change.ngc file.
Maybe also an M2, not sure.
Hmmm... I get only:
- terkaa
25 Jun 2016 06:47 #76634
by terkaa
That does not seem to work either... I tried also python way:
with open('cinci.var', 'r') as file:
# read a list of lines into data
data = file.readlines()
print data[0]
data[0] = '4999 %s.000000\n' % (widget.get_label())
print data[0]
file.close()
with open('cinci.var', 'w') as file:
file.writelines(data)
But it does not work because cinci.var file is already opened by LinuxCNC so writing is not possible. Is there an example of Python writing variables?
Tero
print data[0]
print data[0]
file.close()
Tero
