Help with thcad
9 years 11 months ago #82436 by echesortux
Replied by echesortux on topic Help with thcad
is the value of velocity tolerance a percentage of the total velocity from the machine? I mean
total velocity 100%
velocity tolerance 20%
thank.
9 years 11 months ago #82441 by Rick G
Replied by Rick G on topic Help with thcad
There have been some different versions of the THC, however on yours I believe it is the velocity tolerance.
That is if you set your speed at 200 and you set the velocity tolerance at 20 then
200 * .20 = 40
200 - 40 = 160
So the machine needs to be moving at least 160 for the THC to work.
Rick G
The following user(s) said Thank You: echesortux
9 years 11 months ago #82443 by echesortux
Ok I understand, tomorrow I will do some test with these values and then I will tell you how it was.
Thanks.
9 years 11 months ago #82496 by echesortux
Hello I've made some test today and I noticed that thc.status-vel never is true when machine is cutting. can it be a bug of the thc component. where can I see the source code of thc.comp i have installed in my computer?
I could prove that from this internet thc code I should get a thc.status-vel set to 1 but get always 0.
if(enable){
float min_velocity = requested_vel -(requested_vel*(1/velocity_tol));
if(current_vel > 0 && current_vel >= min_velocity){vel_status = 1;}
else {vel_status =0;}
9 years 11 months ago - 9 years 11 months ago #82499 by echesortux
Can I see the thc source code of thc comp I have installed in my computer? how can I know what is the version i am using ?
as all condition to correction seem to be ok but z axis doesn't move.
ARC-OK true
TORCH-ON true
THC enable true
vel-status true
I don't know why but i have to set the following in .hal file to get vel-status working
setp thc.velocity-tol 40
here you have a pic to see all values while machine is cutting.
Last edit: 9 years 11 months ago by echesortux.
9 years 11 months ago - 9 years 11 months ago #82506 by Rick G
github.com/LinuxCNC/linuxcnc/blob/master.../components/thc.comp
linuxcnc.org/docs/2.7/html/man/man9/thc.9.html
That seems to show a thc.requested-vel of 33.3333
But a thc.current-vel of 25
Are you using the feed override slider to change the speed?
If so be sure to set it at 100%. Setting it too low will cause the THC to not work.
Rick G
Last edit: 9 years 11 months ago by Rick G.
Time to create page: 0.475 seconds
