Probe screen problems... - must be in MDI mode to issue MDI command....
- Mech john
- Topic Author
8 years 11 months ago - 8 years 11 months ago #102393
by Mech john
Probe screen problems... - must be in MDI mode to issue MDI command.... was created by Mech john
I was using the very good probe screen from user 'Verser' (thank you!) and recently upgraded my version of linuxcnc (master) and unfortunately some of the probe screen functions no longer work. Probing the outer diameter of a cylinder for example. The probe will move a small distance in x then stop and generate error message:
Must be in MDI mode to issue MDI command
Probing z down still works however. I had a look in probe_screen.py, is this still a valid command? :
486 self.command.mode( linuxcnc.MODE_MDI )
Any help appreciated!
cheers,
cheers,
Last edit: 8 years 11 months ago by Mech john.
- newbynobi
- Thank you received: 394
8 years 10 months ago #102881
by newbynobi
Replied by newbynobi on topic Probe screen problems... - must be in MDI mode to issue MDI command....
Its a axis gui bug, but inho it has been fixed already
Norbert
Norbert
- jirkam
- Thank you received: 9
5 years 1 month ago #219784
by jirkam
Replied by jirkam on topic Probe screen problems... - must be in MDI mode to issue MDI command....
Hello.
I have the same problem.
I have this version of Linux: Linux digicnc 3.4-9-rtai-686-pae # 1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU / Linux
Which module do I need to update to fix the error?
I can't update everything - I'm afraid something won't stop working for me.
Can you please advise me?
Thank you very much.
5 years 1 month ago #220302
Replied by andypugh on topic Probe screen problems... - must be in MDI mode to issue MDI command....
Which version of LinuxCNC do you have? Your Linux version is (largely) irrelevant.
- Jasper 3
5 years 1 month ago #221342
by Jasper 3
Replied by Jasper 3 on topic Probe screen problems... - must be in MDI mode to issue MDI command....
Hey,
i've the same problem. I'm using linuxcnc 2.8.-pre1-3167-ge375e3a
and i'm using the axis screen.
maybe you can help me out would be great!
best regards Jasper
best regards Jasper
- Jasper 3
5 years 1 month ago - 5 years 1 month ago #221424
by Jasper 3
Ok nevermind got i working, just upgraded my linux to 2.8.2 and it works. kind of. now i have to figure out all the other stuff.
Last edit: 5 years 1 month ago by Jasper 3.
Time to create page: 0.121 seconds
