EL7041 with stepper NEMA17
8 years 7 months ago #107040 by Noal
Replied by Noal on topic EL7041 with stepper NEMA17
NEMA 17 is a bipolar motor for this has 4 wire,the wiring is correct.
his torque is anyway too low for this motor .
in my opinion this problem it's due to the some wrong parameters set in the drive el7041
thank you
8 years 7 months ago #107045 by andypugh
Replied by andypugh on topic EL7041 with stepper NEMA17
I can't think of a driver setting that could make a stepper motor hot _and_ weak.
Not both at the same time.
Some motors have 6 or 8 wires, there are ways to connect those wrongly. No real scope for that with a 4-wire motor though.
The following user(s) said Thank You: Noal
8 years 7 months ago #107047 by Allan
Replied by Allan on topic EL7041 with stepper NEMA17
If you suspect a setting in your motor drive terminal you could reset it back to factory settings.
Perhaps you need larger motors to generate the torque you need?
8 years 7 months ago #107048 by Noal
when i set the current max at 1,8A the stepper it is not hot but the torque is very low, if i try to increase the current the torque increase too, but also the temperature of stepper. The stepper with 1,8A shuold be have more torque (I'm sure of this)
8 years 7 months ago #107106 by andypugh
You can measure the torque using the pulley, a piece of string and a spring balance.
What is the rated torque? You can apply 5Nm with a small screwdriver (10Nm with a big screwdriver), and a NEMA 17 motor will typically make 0.5Nm.
So is it 10% of the torque you can apply with a screwdriver? If it is, then it is working OK.
8 years 7 months ago #107107 by Noal
A colleague of mine tried this engine with another drive and it works, has a good torque and an acceptable overheating.
so maybe the problem is that they are badly set parameters or that the drive is not suitable for this stepper but it seems strange to me.
which parameters could influence this actions?
Time to create page: 0.059 seconds
