Odd, I posted a reply a few weeks ago but it seems it didn't post. I have the magic touch when it comes to internet.
I got the servos working inside the software. I found that I needed to reverse each encoder direction. I also limited the maximum voltage output from 10V to 0.1V so the maximum rpm is 20rpm down from 2000. I had to increase the FError to ~.08" to remove the errors before setting the PID to 20,0,0. I will tune the PID once I have the motors in place. I also checked the direction and made sure it was rotating the right way and that the home position was in the right direction. Also checked the axis hitting the end switches too.
I replaced the spindle motor yesterday. I am also changing the spindle drive from the 0 to the 6 output. I originally had it on 0, but seeing that 6 has an isolated enable is much much better.
Got a new monitor, routed wires to the front. I am waiting on some hex bolts for the belt connections before I can mount the motors. Machined a new mounting plate for the X axis and some bolts along with it.
imgur.com/a/O9cLVxZ
Checked E-Stop circuit. I faulted some equipment on purpose and it shuts everything down. I believe the old power contacter for the spindle and servos are or were always on for some reason. I have a new contacter to put in, but I believe the spindle will fault and disable the E-Stop circuit from turning on if it does not have power. The spindle enable is tied to the 7i77 and the E-Stop circuit. The relay I close to enable the spindle is the same as the old circuit and I have not changed the circuit to the spindle in any way.
The servos have power all the time as is, and, as with the spindle, enable is tied to the E-Stop and cannot run without the E-Stop circuit on.
I am unsure about killing power to the servos and spindle. I do not know what I am achieving killing power compared to killing enable. Enable is tied to E-Stop, and if any of the equipment or the spindle or servos fault, they do kill the E-Stop. I know there are what look like contacters on the main power lines to the spindle and servos, but they conduct even when the power to the machine is off.
