- Thank you received: 1480
kborsum wrote: ....... Also, changing "ldrt_parport cfg="0xe010 out 0xd010 out" to cfg = "0 out 1 out" caused an immediate error when loading the GUI.
No, the BIOS can only control onboard parallel ports.kborsum wrote: DELL Bios editor does not have any way to set up the parallel port cards.
Does it halt at that stage, or carry on? Maybe the error is a fault in LinuxCNC. (though you mention that they are on the same IRQ, and that doesn't sound right, though Google does suggest that IRQs can be shared, so perhaps it makes sense that two identical cards would be on the same IRQ).I've got everything working great, BUT with only one card installed. Installing the second card always generates a port not found error.
