Parallel port problem.
7 years 1 month ago #146042 by TheFabricatorAG
Hi, My neme ir Rodrigo.
I have problems with the parallel port.
I use same PC that Ubuntu had, format and install Debian with LinuxCNC 2.7.14 and the port doesn´t work for me, what can I try?
7 years 1 month ago #146044 by tommylight
Replied by tommylight on topic Parallel port problem.
We need more information.
Start with :
sudo lspci -v
and paste the output here, also attach the hal and ini files so we can check them.
Regards,
Tom.
The following user(s) said Thank You: TheFabricatorAG
7 years 1 month ago - 7 years 1 month ago #146096 by TheFabricatorAG
Hi Tom, tks u very much for your prompt respomse.
Upload the files here.
tks...
Last edit: 7 years 1 month ago by TheFabricatorAG.
7 years 1 month ago - 7 years 1 month ago #146098 by tommylight
You have to change the parallel port pins as they are different from what you need, so open "stepconf" again, choose to edit and existing config, change the pins for :
xstep >pin2
xdir > pin3
Ystep>pin4
ydir >pin 5
zstep >pin6
zdir>pin7
You can also create a new config, just make sure to have the pins set as above.
Last edit: 7 years 1 month ago by tommylight.
7 years 1 month ago #146133 by pl7i92
Replied by pl7i92 on topic Parallel port problem.
did you check the paroprt adress is correct and it is there Parport0 0x378
dmesg | grep parpo*
get above in a terminal
you use the new Standard
What Interface is connected to the Parport and what is behind the interface
as Tom get you to it may be only the DIR/Step swap
7 years 1 month ago #146675 by TheFabricatorAG
Hello guys.
It is none of that, I realized late but it is on the second PC that happened to me but the ISO I downloaded does not work with emc2 2.7.14, install Ubuntu with version 2.5 and no problem is perfect, it makes me very angry But that is the problem.
Time to create page: 0.251 seconds
