curious errors after converting INI from MM to Inch
7 years 2 days ago #149219 by travis036
ok, i scoured the web, and found this: www.newmantools.com/tech/pitchconversions.htm
so with a 5mm ballscrew, i enter a value of 5.08 threads per inch?
~Travis
7 years 2 days ago #149221 by toplakd
Yes.
As 1 inch is 25,4mm, so 25,4/5=5.08
5.08 revs of ballscrew means 25.4mm of travel and that is equal to 1 inch.
7 years 2 days ago #149222 by travis036
dang, so that's where my math went wrong! i tried 5/25.4, instead of 25.4/5!
Thanks!
~Travis
7 years 1 day ago #149306 by travis036
ok, i have a functioning machine again! i finally had time to get out there and "play".
so now i just have to review both config files and compare notes. after i make a backup of the working config, that is.
~Travis
6 years 11 months ago #149543 by andypugh
travis036 wrote: unfortunately, i both updated from 2.7.0 to 2.7.14, and loaded the converted INI file at the same time, so no telling which change caused the conflicts
I don't think that there are any INI changes from 2.7.0 to 2.7.14
Time to create page: 0.052 seconds
