- Thank you received: 43
If two slaved joints are set up, one with a Home offset of -10 the other with -10.253
Is this a setting or hardware switches setup differently?
rogerxue wrote: Thanks, how do I update to 2.9? do I need to compile myself?
Todd Zuercher wrote: Yes
and
Yes
Home (or home position) sets the point where the axis will rapid to and park at the end of the home cycle. Home Offset sets the value given to the point where the home switch is triggered.
So if your switch is at the negative end of travel, and you set the Home Offset = -10
and Home = 0 the joint will home to the switch and rapid move to 10 units away from the switch and that point will = 0.
If two slaved joints are set up, one with a Home offset of -10 the other with -10.253. Both joints will move to their switches, touch off, (which ever one finishes it's touch first will then wait for the other), then both joints will rapid together to the Home = position.
