Spindle PID troubleshooting -- solved
6 years 5 months ago #166676 by tommylight
I can move it there, seems more appropriate .
Thank you.
6 years 5 months ago #166739 by Hakan
Replied by Hakan on topic Spindle PID troubleshooting
First you need to make sure that the pid.s component is actually used. Check the hal file. If you attach it here people can check for you.
If that is all good, I would say to set P=0 and adjust FF0 so the actual spindle speed agrees well with the commanded speed. Judging from your experiments FF0 should be perhaps 1.05.
Then start to increase P until the error is as small as you want. You can go on with I and D. The error is in the pid.s.error pin.
6 years 5 months ago #166777 by PCW
Replied by PCW on topic Spindle PID troubleshooting
Yes, you probably need to increase P, you have
P = 0.4
Which means if you are 100 RPM low the PID output only adds
the equivalent of 40 RPM to the commanded speed...
6 years 5 months ago #166782 by paulctan
That's not the problem. The problem, if you look at the screenshot, is that it's overshooting the compensation, but the hal variables in the screenshot show that it's still below. Screenshot shows the spindle already at 1293 RPM, but the setting is set for 1000 RPM. This is with P=0.4. It should have attempted to decrease the spindle speed, but, if you look at the halshow output, it shows that spindle-vel-fb-rps is 13.94723, and spindle-vel-cmd-rps is 16.6667, so, it's behaving correctly if you look at the rps variables. BUT, the spindle-fb-rpm is 1315.024, and that is CLEARLY above the G code spindle speed of 1000 RPM.
I need someone to tell me what hal variables to look for to further debug this problem.
Thanks.
Paul Tan.
6 years 5 months ago #166784 by PCW
Can you post your hal and in files?
6 years 5 months ago #166786 by paulctan
File Name: Taig_2020-05-05.hal
File Size:12.23 KB
File Name: Taig.ini
File Size:4.89 KB
Time to create page: 0.359 seconds
