Spindle Control using Chinese BOB with blue relay (solved)
- Clive S
- Thank you received: 481
27 May 2020 19:31 - 28 May 2020 17:35 #169145
by Clive S
Spindle Control using Chinese BOB with blue relay (solved) was created by Clive S
Using the standard Chinese BOB with the blue relay I have this working of sorts
Problem as the speed goes up the volts on the output 0-10v goes down .
How do I calibrate it for 2400 rpm spindle with vfd
What would be sane values for the scale, offset, pwm-freq etc.
I am imputing 22V + 5V with the ground connected
#### Spindle stuff ###
net spindle-cmd-rpm => pwmgen.0.value
net spindle-on <= spindle.0.on => pwmgen.0.enable
net spindle-pwm <= pwmgen.0.pwm
setp pwmgen.0.pwm-freq 100
setp pwmgen.0.scale 1000
setp pwmgen.0.offset 0.1
setp pwmgen.0.dither-pwm true
net spindle-cmd-rpm <= spindle.0.speed-out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-cw <= spindle.0.forward
### Parport Pins ###
net spindle-pwm => parport.0.pin-01-out
net spindle-cw => parport.0.pin-14-out
net spindle-on => parport.0.pin-17-out
Last edit: 28 May 2020 17:35 by Clive S.
- Mike_Eitel
- Thank you received: 184
27 May 2020 20:11 #169149
by Mike_Eitel
Replied by Mike_Eitel on topic Spindle Control using Chinese BOB with blue relay
For your invertion:
I'm not sure but believe there is a way to invert the output. Try with negative scale
Second version is that you invert your output parport.0.pin-01-out via
See doc: parport.<p>.pin−<n>−out−invert (bit) Inverts an output pin.
- Clive S
27 May 2020 20:28 #169151
by Clive S
Replied by Clive S on topic Spindle Control using Chinese BOB with blue relay
Thanks I have tried putting the scale -ve I will try changing the parport pin.
- Clive S
28 May 2020 11:16 #169214
by Clive S
Ok I have now tried net spindle-pwm => parport.0.pin-01-out-invert 1 that throws an error (it is shown in the 2.7 docs but not 2.8 that I can see)
Please see the first post for my problem
- Thank you received: 6850
28 May 2020 12:27 #169223
Replied by tommylight on topic Spindle Control using Chinese BOB with blue relay
parallel port outputs are inverted using setp
so
setp parport.0.pin-01-out-invert 1
so
- Clive S
28 May 2020 13:52 - 28 May 2020 14:27 #169232
by Clive S
As above Tom that throws an error with pin does not exist it probably exists in 2.7 I am using 2.8
Edit My bad I was not using setp
so
Last edit: 28 May 2020 14:27 by Clive S. Reason: added text
28 May 2020 14:02 #169233
Works for me on 2.9
It has to be above the pin 1 in hal
like so
setp parport.0.pin-02-out-invert 1
net xstep => parport.0.pin-02-out
Works for me on 2.9
like so
- Clive S
28 May 2020 14:26 #169235
by Clive S
sorry, sorry , sorry my bad I was trying spindle-pwm => parport.0.pin-01-out-invert 1
but I had to do setp parport.0.pin-01-out-invert 1 and missed it.
Now that get me the 0-10v going up as the speed change goes up
setp pwmgen.0.scale 24000 setting this gets me the 24K on the vcp display
setp pwmgen.0.offset 0.1 What does this do
Works for me on 2.9
like so
28 May 2020 15:56 #169237
It just sets the output a bit higher than 0 , so when you start the spindle it does not start at 0RPM.setp pwmgen.0.offset 0.1 What does this do
