Tandem Z axis suddenly homing in opposite directions
- Bearfood
When I access each Z joint the + moves the joint up and - moves the joint down on both sides. Homing however, one goes up and one goes down even though it's setup as a tandem joint.
Z is set up as a 4" height 0 being at the top with a -4" travel. Home towards the positive limit, final home position of 4.
Any thoughts?
hal and ini attached.
Tried rebooting the controller and PC with no change
- Clive S
- Thank you received: 486
MIN_LIMIT = -4.0
MAX_LIMIT = 4.001
HOME_OFFSET = 4.000000
HOME_SEARCH_VEL = 0.066667
HOME_LATCH_VEL = 0.016667
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
Re: HOME_SEQUENCE = 0 for tandem axis this needs to be a -ve number in both joints.
I don't think -ve zero will work.
Also the jog keys won't jog the correct axis until it is homed.
- Thank you received: 7465
HOME_SEARCH_VEL = 924983 <<<just some numbers
To change the direction add a - , or remove it if there is one already.
- Thank you received: 2173
could this be the problem?
The fact it changed over time leads me to this being likely.
other possibility is not running the config you thought you were.
- Bearfood
The other oddity that I noticed while troubleshooting is that when I auto home the joints and the Z is doing it's thing going backwards I can manually depress the Z home switch and the gantry doesn't stop moving down. The voltage on the switch does change but the behaviour does not. Does that help?
- Bearfood
I can't for the life of me understand why. I've been through the pncconf a few times and updated it with no affect until I touched that specific setting and re-saved it. Anyways, hopefully this helps someone else out down the road.
Thanks for your help!
- Thank you received: 5315
(once parsed and turned into a sequence number) so would not
force synchronized homing
Did you check that (via halmeter or halshow)
joint.3.home-sw-in
and
joint.4.home-sw-in
change appropriately when you activate the Z home switches?
- Bearfood
Once I had the machine running I loaded up the attached g-code for a zero clearance insert and couldn't get it to start. I thought perhaps because I removed the tool change in the pncconf earler but no matter what I did the machine wouldn't move under its own command. I tried restarting LinuxCNC which then meant I needed to rehome. Upon hitting the home all button the damn Z axis started going in the opposite directions again.
G-code attached along with the current ini and hal files
Here's precisely what I did.
1) loaded Linuxcnc
2) home all
3) moved Z down
4) moved X
5) touch off X (touch off button)
6 Moved Y
7) touched off Y
8) moved Z down
9) touched off Z
10) pressed run and nothing happened, no errors, no movement, no noise
Thoughts? This is really frustrating.
- Bearfood
Edit OK if pncconf uses -0 that's a pncconf bug
(integers like sequence numbers cannot represent -0)
I would renumber the home sequence number starting at -1 for Z
This may not fix all of you issues but will at least
force the Z joints to do synchronized home moves
