Homing direction problem
13 May 2021 19:25 #208750 by robertjenkins
Homing direction problem was created by robertjenkins
With my Denford Micromill the end switches are at the furthest extent of travel. There are no zero switches, so the homing has to be done at the max point. For some reason, both X and Y axes regularly go off in the wrong direction so never reach these switches, and pressing the end switch does not stop the steppers, even though the switches are connected correctly. I say regularly, but I can't point to anything that's different when they do this. They seem to be wired correctly, because jogging sends them in the right direction. The Z axis homes itself fine. I attach the hal and ini files although it feels like a hardware issue.
File Name: my-mill2ini.txt
File Size:2 KB
File Name: my-mill2hal.txt
File Size:3 KB
13 May 2021 19:59 #208753 by robertjenkins
Replied by robertjenkins on topic Homing direction problem
Update: I did a bit of reading here (original approach, I know) and discovered that changing the homing speed to negative sometimes fixes things. So I did this, and now the Z and X axes go in the right direction. But the X doesn't recognise the stop switch, so I never get to Y. Normally the stop switch is connected to ground, except when it it is pressed. Do I need a pullup resistor to tell the the Bob that the switch has been pressed?
13 May 2021 22:39 #208766 by robertjenkins
Further update.
The X stop switch still has no effect. But I have measured the voltage on that pin on the bob, and when the switch is pressed, the voltage goes from 0 to 9V. (This surprised me - I was expecting 5V).
I've tried swapping round the input pins (and stepconf), but whichever one the X switch is connected to, it has no effect on stopping the stepper then moving.
I am baffled
13 May 2021 23:28 #208768 by PCW
Replied by PCW on topic Homing direction problem
Does the hal pin parport.0.pin-12-in change when you activate the switch?
13 May 2021 23:31 #208769 by robertjenkins
Yes, although i have not traced it as far as the pc, only to the Bob. Is there a way of seeing what the pc is getting?
14 May 2021 00:02 - 14 May 2021 00:07 #208770 by PCW
Yes, when LinuxCNC is running select machine --> show hal configuration and
select parport.0.pin-12-in from the list of pins, then select the "Watch" tab
Alternatively, in a terminal window when LinuxCNC is running, type:
halmeter pin parport.0.pin-12-in
Last edit: 14 May 2021 00:07 by PCW.
14 May 2021 11:11 #208791 by robertjenkins
So I have used Hal meter which shows all three switches go from false to true when pressed but don’t cause the steppers to stop
  • Moderator
  • Moderator
14 May 2021 11:44 #208796 by tommylight
Replied by tommylight on topic Homing direction problem
Post your actual hal and ini files here.
14 May 2021 11:48 #208797 by robertjenkins
They are attached to my original post
14 May 2021 13:33 #208803 by bevins
Replied by bevins on topic Homing direction problem
I dont see no limit switches. Just home switches and they are not shared in the ini. So to me it looks like you have no limit switches.
Time to create page: 0.099 seconds
