Backoff when limit switch is hit
5 years 3 weeks ago #222593 by hwe
how can I set a backoff distance when the limit switch is hit ?
Currently the axis hits the limit switch and gets stuck - no way to move the table, unless I unpower the CNC and manually move the table until the switch is deactivated.
Nothing found in pncconf to set it.
Nothing found by searching the forum/google for 1h.
I assume I can set it in the .ini file, but how ?
5 years 3 weeks ago #222598 by tommylight
Put a - in front of the home_latch_velocity or remove it if it is already there.
5 years 3 weeks ago - 5 years 3 weeks ago #222641 by hwe
Nothing like this found in .hal not .ini.
I want to use "Limit-All" on Pin4 of my Mesa 7i92 with DIY breakoutboard.
I want the machine to detect the limit and then backoff by 5mm to release the switch.
I do not want to detect any HOME position. I am homing manually.
The function "Limit All" works and detects the switch, but does not backoff.
After playing with pncconf settings:
- Function "Limit+Home All" did not at all detect (or react) on the switch.
I think I need a little bit more explanation about how to setup the limit+backoff - if this is possible at all.
I did not find any meaningful setting in pncconf.
The documentation also did not enlight me very much.
Can you explain in greater detail if its possible to use "Limit-All" and have a backoff on all axis ?
Edit:  I found the checkbox in AXIS to deactivate limits - this at least lets me move the table back from the limit switch !
I think this is the function I was looking for - its manual, but it enables to release the switch and not get stuck at the limit.
Last edit: 5 years 3 weeks ago by hwe.
5 years 3 weeks ago #222727 by rodw
Remember that limit switches should never be hit and are just there for safety.
So having a manual process is the correct way so you can resolve whatever went wrong....
5 years 3 weeks ago #222735 by phillc54
Limit + backoff is not possible.
Combined Home/Limit + backoff is possible during homing:
linuxcnc.org/docs/2.8/html/config/ini-ho...witch_example_layout
Soft limits (the ini file MAX_LIMIT & MIN_LIMIT) should be set inside physical limit switches so the limit switch will not normally be hit unless something goes wrong.
5 years 3 weeks ago - 5 years 3 weeks ago #222736 by hwe
Hi
thanks for the clarification and I feel I have to better understand the usage of a HOME position.
So far I was thinking abut limit switches as you describe - never try to hit them.
The HOME position is basically the position where the machine rests when not in use.
But it rarely is the (0,0,0) position of my work-piece at the same time, right ?
I could combine HOME+LIMIT positions and I think this is what I will do.
What I see in my AXIS GUI is only a "Referenzfahrt" (german for reference run) for each axis and this searches for the HOME position by acitvating limits/home switches.
But how can I set the (0,0,0) position on the workpiece ?
This position is different from the HOME position, but I find no button how to set the coordinate system to (0,0,0).
Time to create page: 0.162 seconds
