Glass scales index
4 years 9 months ago #232708 by PCW
Replied by PCW on topic Glass scales index
Index will work at almost any speed because it does not depend
on LinuxCNCs servo thread rate but rather is implemented in hardware
in the encoder counter.
The way to check index operation is not by looking at the index
input (which is limited by LinuxCNC's servo thread period sampling)
but rather setting index-enable true and seeing if it gets set false
when the index signal occurs.
4 years 9 months ago #232756 by einarak
Replied by einarak on topic Glass scales index
Works like a charm, so the problem newer was a problem! Thanks for the inoput
The following user(s) said Thank You: tommylight, HalaszAttila
Time to create page: 0.048 seconds
