Mesa 7i76 spindle issue
4 years 8 months ago #234922 by Kadrick
When I start linuxcnc I can start my spindle with button or with MDI M3 S20000. All seem to be OK. But when I start a code, spindle start and cut immediately at next line.
If I add G4 P10 just after M3 S20000, spindle rotate during 10s and then stop when line G0 X0 Y0 is read.
My configuration has been describe in this topic:
forum.linuxcnc.org/27-driver-boards/3841...ection-issues#228910
Someone can help me?
4 years 8 months ago #234931 by tommylight
4 years 8 months ago - 4 years 8 months ago #234937 by Kadrick
Replied by Kadrick on topic Mesa 7i76 spindle issue
I attached my code.
But you will see, there are nothing very exotic.
It seems that I have something wrong with my card because when the spindle stop due to next line, I have to restart (turn off, turn on) my controller, if not button for start spindle manaully doesn't work.
Last edit: 4 years 8 months ago by Kadrick.
4 years 8 months ago - 4 years 8 months ago #234940 by Kadrick
Problem doesn't come from hardware because restarting controller is in fact not necessary. Only linuxcnc have to be restarted.
After restarting it is possible to launch spindle but when I start code without M3 S20000 and I stop, after that, command of spindle is desabled (button and MDI M3 S).
4 years 8 months ago #234951 by PCW
Replied by PCW on topic Mesa 7i76 spindle issue
What are the states of spindle on and spindle speed out
when the spindle stops?
4 years 8 months ago #234952 by tommylight
Replied by tommylight on topic Mesa 7i76 spindle issue
Ground the spindle and VFD.
That sounds like interference, so much of it that it disables the Mesa board.
Or, check the VFD COM pin, it has to be wired near the +10V and VA (or whatever the control pin is called), not to any other COM on the VFD.
Time to create page: 0.412 seconds
