- Thank you received: 4
Unfortunatly I'm currently suffering from a broken neck, got hit by a car while cycling
-What kind of EMF filters did you use for the drives?.
-For configuring the DI's and DO's, how do you tell Linux which has what kind of function?
-Did you feed the encoder signal from the drive back to the Mesa board?. Not sure if this will work or only create issues while running in step/direction mode.
In the future I want to add the glass scales to the drives but for now first focus on getting LinuxCNC + the Delta drives to work.
