Joint 3 limit error
4 years 1 month ago #251345
by RobKin
Joint 3 limit error was created by RobKin
I am at the stage in my build where I am verifying all my limit switches work and everything is right before attempting a Home for the first time.
Got everything working good except Z-Max limit switch that I added.
With machine ON if I actuate this switch I get an error:
Joint 3 limit switch error, Machine Error: Joint 3 on limit switch
How do I fix this is there a problem in my hal or ini?
4 years 1 month ago #251347
Replied by PCW on topic Joint 3 limit error
To me, that seems like the proper response to hitting the max limit
4 years 1 month ago #251351
by RobKin
Replied by RobKin on topic Joint 3 limit error
My other limit switches don't do that if I actuate them. Are those setup wrong then?
4 years 1 month ago #251352
by RobKin
I take that back, just checked and they do it also. Sorry still learning
Time to create page: 0.199 seconds
