Error setting TOOL_CHANGE_POSITION
- RotarySMP
- Thank you received: 595
14 Oct 2022 19:30 #254131
by RotarySMP
Error setting TOOL_CHANGE_POSITION was created by RotarySMP
On my Schaublin, I will get started using a manual QCTP holder. So I want the lathe to retract X to 180, have me change the tool, and then continue. I have Gmoccapy's tool change working fine, except for the move to the change location in X. When I add this to the INI:
[EMCIO]
TOOL_CHANGE _POSITION = 180
I get the error
estop.hal:4: Pin 'iocontrol.0.user-enable-out' does not exist
If I comment out that TOOL_CHANGE _POSITION line, LinuxCNC loads fine, and the HALSHOW shows that iocontrol.0.user-enable-out does exist.
Looks like IOcontrol gets built later in start up than that INI line is read. Any ideas how to address that?
Mark
[EMCIO]
I get the error
Mark
- Online
- Thank you received: 7478
14 Oct 2022 21:17 #254134
Replied by tommylight on topic Error setting TOOL_CHANGE_POSITION
180 what????
Try
TOOL_CHANGE _POSITION = X180
180 what????
Try
- RotarySMP
15 Oct 2022 06:48 - 15 Oct 2022 06:56 #254153
by RotarySMP
Replied by RotarySMP on topic Error setting TOOL_CHANGE_POSITION
Thanks Tommy.
I had followed the example in the docs, which listedÂ
TOOL_CHANGE_POSITION = 0 0 2 - Specifies the XYZ location to move to when performing a tool change if three digits are used. Specifies the XYZABC location when 6 digits are used. Specifies the XYZABCUVW location when 9 digits are used. Tool Changes can be combined. For example if you combine the quill up with change position you can move the Z first then the X and Y.
I'll try adding the X and report back.
Last edit: 15 Oct 2022 06:56 by RotarySMP.
- RotarySMP
15 Oct 2022 10:12 #254159
by RotarySMP
I added the X, but that is not the issue. Same error as before.
Mark
Mark
- Online
15 Oct 2022 11:07 #254162
Adding all 3 values?
- Thank you received: 2181
16 Oct 2022 01:44 #254201
Replied by cmorley on topic Error setting TOOL_CHANGE_POSITION
How about just two values, if you only have two axes..
- Online
16 Oct 2022 14:24 #254228
Yup, forgot he was talking about a lathe, despite watching that lathe on youtube several times!How about just two values, if you only have two axes..
- RotarySMP
23 Oct 2022 10:21 #254840
by RotarySMP
Sorry slow reply, I had a work trip this week.
I have tried adding a value for Z, but always the same error.
Mark
Mark
- Thank you received: 4654
24 Oct 2022 10:28 #254893
Replied by andypugh on topic Error setting TOOL_CHANGE_POSITION
I think you need three numbers, separated by spaces, and no coordnates.
For a lathe just use a zero as the placeholder for Y.
(Not that I have bothered to test this, of course)
24 Oct 2022 13:02 #254904
here is the docs:
