AutoLogin - Solved
15 Jan 2024 16:24 #290767 by slowpoke
AutoLogin - Solved was created by slowpoke
I'm a total Linux newbie, so please bear with me....
I have installed LinuxCNC 2.91 under Debian12.
This PC will only be dedicated to a milling machine and will only by used by me, and will probably not be connected to the internet so it would be more convenient if on power-up the login and password screen would simply be bypassed. This might be more of a Debian question however I can't seem to find a how to regardless of where I search, I did find one reference stating to modify
lightdm.conf
So I opened a command prompt and typed "sudo nano /etc/lightdm/lightdm.conf" and then removed the '#' for the following two lines (I assume the # means comment) and added my user name after =
Changed.....
#autologin-user=
#autologin-user-timeout=0
to
autologin-user=myusername
I then did ^O, and ^X the file appears to have been updated, because when I reopen the file I can see my changes.
This does NOT seem to work and does not address the password aspect.
Suggestions welcome.
  • Moderator
  • Moderator
15 Jan 2024 17:00 #290771 by tommylight
Replied by tommylight on topic AutoLogin - Solved
Been to long, but, i think there are several entries with those same lines in different sections of the conf file, the lines under the "seat" section have to be modified/activated for it to work.
And myusername should be the user name you log in with, not "myusername".
The following user(s) said Thank You: abdulasis12
15 Jan 2024 17:15 #290773 by slowpoke
Replied by slowpoke on topic AutoLogin - Solved
tommylight,
I did modify the lines under "seat" and "myusername" is my actual username, so it's something else.
15 Jan 2024 19:04 - 15 Jan 2024 19:05 #290780 by slowpoke
Solved!
Not enough coffee, I had one extra 'l' in the username in the file
Thanks for responding.
Last edit: 15 Jan 2024 19:05 by slowpoke.
16 Jan 2024 03:13 #290826 by abdulasis12
Replied by abdulasis12 on topic AutoLogin - Solved
lightdm.conf
Changed.....
#autologin-user=
to
I try your solution but my pc can't to autologin  hahahaha
have any idea or check ?
autologin-user =asixx
autologin-user-timeout =0
ctrl + O
ctrl + X
18 Feb 2024 04:14 - 18 Feb 2024 04:15 #293666 by jimmejames
Replied by jimmejames on topic AutoLogin - Solved
@adbulasis12 - did you make sure you set the parameters under the [Seat:*] heading as @tommylight mentioned? This was around row 128 in the lightdm.conf file.
I started with the inputs under the [LightDM] heading as that's the first place I saw the sample parameters, but autologin did not work. When I changed the location, my autologin worked.
Note, I needed to change to root to save my changes ("sudo -i" at a terminal).
Information from here:
wiki.printnc.info/en/controllers/linuxcnc/install
Last edit: 18 Feb 2024 04:15 by jimmejames.
The following user(s) said Thank You: tommylight, abdulasis12
Time to create page: 0.081 seconds
