Versa Probe with Qtdragon hang
2 years 4 months ago - 2 years 4 months ago #302228 by looping
Hello
Randomly, when I Z probe, QtdragonHD just hang after the first contact with the workpiece. The green probe light flashes once the, then every thing stops for 30 sec. Then a popup shows the following message:
ERROR INFO: Probe routine: Probe down: latch return failed: Command timed out: (30 second)
When this occurs, all next probing down attempts will fail.
Yesterday, I found that hitting the "Machine On" button twice could reset the process and allow other succesfull Z probe.
I never experienced this when probing on X and Y.
Last edit: 2 years 4 months ago by looping. Reason: Youtube link
1 year 8 months ago #320397 by h_munktell
Did you resolve this? I have a similar or the same problem with qtdragon and basicprobe.
1 year 8 months ago #320424 by JohnnyCNC
This may not help much but I have been using Basic Probe with LCNC 2.9.3 and now 2.9.4 with QTDragon_HD and have not seen this issue.
1 year 8 months ago #320799 by h_munktell
It's annoying that it is random, I can not up till today reproduce the error. Last days of dry running and testing macro codes with probing procedures has not triggered it. But I bet the moment I go live and try to cut something the error will happen.
If I only knew what to look for in HALshow or some logfile, troubleshooting would be easier....
1 year 8 months ago #320808 by cmorley
This is typical of the move length and speed not being finished in the timeout requirement.
But that seems strange on the latch return.
What version of linuxcnc are you using and can you post a pic of the probe settings you are using (when it failed)
1 year 8 months ago #320848 by h_munktell
I'm on 2.9.3, to my knowledge, I have not seen any changes in the values on the probe screen when it fails. I "think" I have seen a command in the linux status window, indicating a retract command when it is halting. But will double check next time.
This is how it looks when it works at least
Time to create page: 0.334 seconds
