7i97T with Mesa CT- Desn't seem to be outputting an analogue signal.
2 years 2 weeks ago #311907 by flyingbrick
Hi all.I have taken a look through the forums here and had a heavy google search- I had a few leads but all parts of my code appear OK where others seem to have failed.I was trying to identify if it was my drives not responding to signal, my wiring being incomplete, or my HAL setup.. could be all of them but I am unable to pick up any output from the mesa board via multimeter or drive monitoring software.Please see attached- any assistance very much appreciated.
File Name: io.hal
File Size:260 B
File Name: main.hal
File Size:7.07 KB
File Name: tauheicnc.ini
File Size:3.28 KB
2 years 2 weeks ago #311912 by tommylight
There is nothing regarding spindle in those files, except the ON pin.
Try again or edit this but do check if the spindle stuff is checked in the wizard.
The following user(s) said Thank You: flyingbrick
2 years 2 weeks ago #311914 by flyingbrick
Correct - there was no way of configuring the spindle using my card and mesa CT - But that was a hurdle to jump another day :-) it should still work tho right? Or does it NEED spindle??
2 years 2 weeks ago #311924 by PCW
When linuxcnc is running and you expect an analog output
can you run:
halcmd show all > all.txt
in a terminal window and port all.txt here?
2 years 2 weeks ago #311925 by flyingbrick
Hi PCW.
Attached. I cant do it while actually trying to generate an output as it errors within a moment due to movement error
2 years 2 weeks ago - 2 years 2 weeks ago #311926 by flyingbrick
edit to clarify.
When i look at halconfig and PWM enable and value,
00 and 01 enable when i turn on the machine within lcnc
I can jog X and get 00 to flash up a value. 01 and 02 do not do this (02 probably because its not enabled)
Last edit: 2 years 2 weeks ago by flyingbrick.
Time to create page: 0.289 seconds
