- Thank you received: 3
Note that it says that it is 'reading setup parameters:' which fails. Enabling the spindle would not be a read function.MAYBE the actrual issue here is the register to say enable spindle is the incorrect register in my drive, so the response is illegal data address?
The component does not handle exception responses (which are only 5 bytes), I guess.Is it odd that there is only 6 bytes received then a time out occurs?
No, modbus uses a crc checksum (ie the last two bytes of the messages). If your request got corrupted the crc would be wrong and the vfd would then ignore the request and you would not receive any response.Could I have some type of issue with the comms and data is getting corrupt?
No, the layout is:If I understand this correctly, it is trying to read the data starting at address 0305h?
If thats true, I think that address does not exist in my controller.
