Only one of the gantry joints move
28 Oct 2024 21:25 #313387 by Malteser01
Only one of the gantry joints move was created by Malteser01
Hello there!
I have recently mostly finished my CNC mill. It is a 3 axis moving gantry, with two motors on the Y axis.
After lots of troubleshooting and learning about linuxcnc, I finally (!) got all 4 joints to home.
I can jog X and Z as I should be able to, but with Y that's a different story: only one of the Joints moves during jogging.
After only implementing the 4 joints and declaring joint_1 and joint_3 as Y in the ini didn't work, I tried adding loadrt gantry [.....] . The syntax with this one is a hassle. About 3 hours later I got linuxcnc to post with it, only to find out that it didn't change anything at all.
I can later (got them on a thumb drive right now) post my .hal and .ini if that helps. Maybe someone knows an answer already.
Thanks to you all in advance!
28 Oct 2024 21:45 #313390 by tommylight
Replied by tommylight on topic Only one of the gantry joints move
Need some more info:
-parallel port or Mesa or something else?
-where did you get the info about loadrt gantry thing?
29 Oct 2024 05:40 #313410 by Malteser01
Replied by Malteser01 on topic Only one of the gantry joints move
Parallel port +bob. Mesa was too expensive for me for a proof of concept.
I found the gantry command (if it's called that) in the linuxcnc documentation, and thought that it might solve the problem.
Thing is: the problem stands with or without loadrt gantry. All the axis home, but only one of the ys moves while jogging.
29 Oct 2024 06:54 #313412 by Aciera
Replied by Aciera on topic Only one of the gantry joints move
- gantry component is obsolete in versions 2.8 and later
- please post your hal and ini files.
29 Oct 2024 21:38 #313457 by Malteser01
So, now that I finally found time and access to a pc, I can share my .hal and .ini
I really appreciate any effort anyone puts into this.
29 Oct 2024 22:21 #313459 by tommylight
Yeah, to many things missing and/or wrong there, or wrong config files.
Use StepConf wizard to make a new config and choose as shown in the attached picture:
30 Oct 2024 06:23 #313472 by Malteser01
Okay then, I'll try stepconf again.
Hoe would I then teach the machine to accept a as y2? As far as I'm aware, there's no setting in stepconf for that.
30 Oct 2024 13:06 #313483 by tommylight
What version of LinuxCNC?
2.10 has tandem limits so it should have tandem joints also.
30 Oct 2024 15:45 #313489 by Malteser01
2.9.3 I believe. I just installed it a few weeks ago.
30 Oct 2024 19:56 #313509 by rodw
Replied by rodw on topic Only one of the gantry joints move
Setting tandem axes is done when homing. It is all covered in the documents under the heading "Homing Configuration"
You need to read it a few times before it sinks in.
each tandem joint needs a negative HOME_SEQUENCE
