Actual position and Commanded position differ, using cia402
  • low-blip
  • New Member
  • New Member
16 May 2025 10:30 #328550 by low-blip
I'm very new to LinuxCNC, and using a CNC machine custom built and configured by someone else. Running into some errors that none of us could figure out, help would be very very appreciated.
We are using cia402 and ethercat to run a 9-axis system, including xyz and 6 rotation axis. We noticed that the actual and commanded positions of the xyz axes are always off by a factor of 80 , e.g. if we send the Gcode to move X axis by 10mm, it moves by 10mm, the commanded position is 10, but the 'actual position' is 0.125. We can still run .ngc files, they do exactly what we expect them to do, but at the end we get motor position error on these three axes.
We've tried increasing the FERROR and MIN_FERROR in the .ini file and adding a scaling factor to the joint.N.motor-pos-fb in the .hal, both end up causing gain error instead.
I've attached the .ini and .hal configurations, but i'll also put the maybe relevant parts here:
.ini:
[AXIS_X]
MIN_LIMIT         = -5
MAX_LIMIT         = 395
MAX_VELOCITY         = 500
MAX_ACCELERATION     = 250
[JOINT_0]
TYPE             = LINEAR
MAX_VELOCITY         = 500
FERROR             = 200
MIN_FERROR         = 50
MIN_LIMIT         = -1
MAX_LIMIT         = 1200
HOME            = 0
HOME_OFFSET        = 0
HOME_SEQUENCE        = 1
HOME_IGNORE_LIMITS    = YES
# nach github.com/dbraun1981/hal-cia402/blob/main/README.md
HOME_SEARCH_VEL     = 5.0
HOME_LATCH_VEL         = -2
HOME_FINAL_VEL        = 1
HOME_USE_INDEX    = FALSE
 .hal:
loadrt [KINS]KINEMATICS
loadusr -W lcec_conf ECOMODUL_ethercat_conf.xml
loadrt lcec
loadrt cia402 count=9
# Functions servo-thread
addf lcec.read-all servo-thread
addf cia402.0.read-all servo-thread
addf cia402.1.read-all servo-thread
addf cia402.2.read-all servo-thread
addf motion-controller servo-thread #########################################
#nets
net emc-enable => iocontrol.0.emc-enable-in
sets emc-enable 1 #config
#testing Werte für pos-scale fehlen
#x
setp cia402.0.csp-mode 1
setp cia402.0.pos-scale 8000
#y
setp cia402.1.csp-mode 1
setp cia402.1.pos-scale 8000
#z
setp cia402.2.csp-mode 1
setp cia402.2.pos-scale 8000 ...
#from servo(ethercat) to cia402 net x-statusword      lcec.0.8Axis.xcia-statusword => cia402.0.statusword
net x-opmode-display  lcec.0.8Axis.xopmode-display => cia402.0.opmode-display
net x-drv-act-pos     lcec.0.8Axis.xactual-position => cia402.0.drv-actual-position net y-statusword      lcec.0.8Axis.ycia-statusword => cia402.1.statusword
net y-opmode-display  lcec.0.8Axis.yopmode-display => cia402.1.opmode-display
net y-drv-act-pos     lcec.0.8Axis.yactual-position => cia402.1.drv-actual-position  net z-statusword      lcec.0.8Axis.zcia-statusword => cia402.2.statusword
net z-opmode-display  lcec.0.8Axis.zopmode-display => cia402.2.opmode-display
net z-drv-act-pos     lcec.0.8Axis.zactual-position => cia402.2.drv-actual-position
#from cia402 to servo(ethercat) net x-controlword         cia402.0.controlword     => lcec.0.8Axis.xcia-controlword
net x-modes-of-operation  cia402.0.opmode     => lcec.0.8Axis.xopmode
net x-drv-target-pos      cia402.0.drv-target-position   => lcec.0.8Axis.xtarget-position net y-controlword         cia402.1.controlword     => lcec.0.8Axis.ycia-controlword
net y-modes-of-operation  cia402.1.opmode     => lcec.0.8Axis.yopmode
net y-drv-target-pos      cia402.1.drv-target-position   => lcec.0.8Axis.ytarget-position net z-controlword         cia402.2.controlword     => lcec.0.8Axis.zcia-controlword
net z-modes-of-operation  cia402.2.opmode     => lcec.0.8Axis.zopmode
net z-drv-target-pos      cia402.2.drv-target-position   => lcec.0.8Axis.ztarget-position
#from motion to cia
net x-enable    <= joint.0.amp-enable-out => cia402.0.enable
net x-amp-fault => joint.0.amp-fault-in   <= cia402.0.drv-fault
net x-pos-cmd   <= joint.0.motor-pos-cmd  => cia402.0.pos-cmd
net x-pos-fb    => joint.0.motor-pos-fb   <= cia402.0.pos-fb net y-enable    <= joint.1.amp-enable-out => cia402.1.enable
net y-amp-fault => joint.1.amp-fault-in   <= cia402.1.drv-fault
net y-pos-cmd   <= joint.1.motor-pos-cmd  => cia402.1.pos-cmd
net y-pos-fb    => joint.1.motor-pos-fb   <= cia402.1.pos-fb net z-enable    <= joint.2.amp-enable-out => cia402.2.enable
net z-amp-fault => joint.2.amp-fault-in   <= cia402.2.drv-fault
net z-pos-cmd   <= joint.2.motor-pos-cmd  => cia402.2.pos-cmd
net z-pos-fb    => joint.2.motor-pos-fb   <= cia402.2.pos-fb
16 May 2025 14:48 - 16 May 2025 16:02 #328568 by langdons
You mean if you home the axes and then run a program, then jog them to home, they don't reach home?
Are the axes driven by leadscrews?
Are these stepper motors?
SIDE NOTE:
My machine had measurement errors, it turned out that the axes were actually in mm not inches.
20" and 500mm are actually pretty close.
Last edit: 16 May 2025 16:02 by langdons. Reason: Removed dumb garbage.
16 May 2025 14:52 - 16 May 2025 16:03 #328572 by langdons
Deleted.
Last edit: 16 May 2025 16:03 by langdons. Reason: Deleted.
  • Hakan
  • Platinum Member
  • Platinum Member
16 May 2025 14:59 #328573 by Hakan
langdons, sometimes it is better not to answer. It should be obvious from the post that this is an ethercat machine.
I don't see anything obvious wrong in the setup.
8000 is a lot, 8000 steps or ticks or whatever per mm but that is probably right since it moves right.
What you can do to debug this is to use "halshow" and look at all pins in the chain from joint.0.motor-pos-cmd to the cia402 pin, to the driver pin, and the return from the driver pin, to the cia402 pins, to joint.0.motor-pos-fb pin.
The following user(s) said Thank You: low-blip
16 May 2025 16:05 #328578 by langdons
Sorry.
Will read more carefully next time.
  • low-blip
  • New Member
  • New Member
19 May 2025 09:44 #328731 by low-blip
I can't jog or do anything after running a program, I get motor position error on xyz axes afterwards and have to restart linuxcnc before I can reconnect to the machine. Same thing if I run a few lines in MDI mode and switch back to manual control.
Yes the x, y and z axes are driven by leadscrews.
Yes they are stepper motors.
I did double check the unit last week, we have everything set in mm. I wish it was as simple as that.
  • Hakan
  • Platinum Member
  • Platinum Member
19 May 2025 10:39 #328732 by Hakan
Did you try with halshow? That is the way to debug this.
When linuxcnc is still running, start halshow in a terminal window. The machine can have e-stopped, that's ok.
Just type halshow at the prompt.
Navigate through pins and investigate the values of the pins outlined above.
This should hopefully give an understanding of where things go wrong.
  • low-blip
  • New Member
  • New Member
19 May 2025 11:07 - 19 May 2025 12:02 #328733 by low-blip
I just tried that, not sure if I found something useful but something strange did come up.
The pins I looked at were:
joint.0.pos-cmd
joint.0.pos-fb
cia402.0.pos-cmd
cia402.0.pos-fb
axis.x.pos-cmd
all seem like they're what they should be except axis.x.pos-cmd, after I sent G0 X50 in MDI mode, it was 50, everything was fine, then I switched to manual control mode, it changed to 0.625. That is also when I get the motor position error.
I took some screenshots at startup, after homing, after sending a G0X50 command and after I got the error. I don't have anywhere to host the images though, so I put them in the attachment in case that helps.
Last edit: 19 May 2025 12:02 by low-blip.
  • Hakan
  • Platinum Member
  • Platinum Member
19 May 2025 12:31 #328739 by Hakan
Suddenly a big shift in axis.x.pos-cmd while joint.0.pos.cmd stays? When you shift between MDI and Manual.
The translation between joints and axis is done in the kinematics module but there are more things involved I don't know so much about.
I see you have a userkins module, that one becomes suspicious of course.
You can follow the signals, ms by ms, using the halscope utility.
Maybe interesting to do that when you shift between MDI and manual.
Judging from the halshow output you EtherCAT drives behave as they should. The problem isn't there.
The following user(s) said Thank You: Aciera, low-blip
19 May 2025 13:11 #328741 by Aciera
I agree, this is most likely a problem with your custom kinematic module. I usually see these kinds of jumps when the forward and the inverse kinematics do not match up.
Time to create page: 0.329 seconds
