problem with homing
  • hanz24
  • Topic Author
  • New Member
  • New Member
11 months 3 weeks ago #338068 by hanz24
problem with homing was created by hanz24
I have a problem with homing in the lcnc sim. First, i jog the axis xz and then try to home all axis, and it's works. But when i try to do that again, its only homing for the x axis, and z axis didn't go to the home coordinate. Already check the ini file and it's all same with x and z axis, what can i do to solve this.
And i also want to try to jog a-axis with external push button, is this hal configuration enough to do that
setp halui.axis.a.jog-speed 100 net jog-a-plus-raw debounce.0.0.in <= hm2_7i98.0.gpio.001.in_not  net jog-a-plus debounce.0.0.out => halui.axis.a.plus net jog-a-minus-raw debounce.0.1.in <= hm2_7i98.0.gpio.005.in_not net jog-a-minus debounce.0.1.out => halui.axis.a.minus
  • Moderator
  • Moderator
11 months 3 weeks ago #338081 by tommylight
Replied by tommylight on topic problem with homing
You say that and go on to show actual hardware pins, so are you using a simulation or real hardware?
11 months 3 weeks ago #338084 by Aciera
Replied by Aciera on topic problem with homing
Usually a good idea to indicate which sim you are using so people can try to reproduce the issue. I have tried on an Axis sim and could not reproduce this.
  • hanz24
  • Topic Author
  • New Member
  • New Member
11 months 3 weeks ago #338130 by hanz24
Replied by hanz24 on topic problem with homing
sorry for the misunderstanding. i'm using hardware with mesa 7i98 and 2 stepper motors with Axis UI. and like i said before, i can't do homing properly after doing it for the second time. when homing for the first time, the x and z axes are going back to the 0 position. but when i try to home again, only x axis goes to 0, the z axis doesn't move at all.
Time to create page: 0.108 seconds
