Remora - Cannot clear E-STOP, without error
8 months 1 week ago #343346 by AlessandroEmm
Setup:
  • LinuxCNC with Remora SPI controller
  • 4-axis gantry configuration (XYYZ - dual Y motors)
My System is stuck in E-STOP state and cannot be cleared with F1 or any other method in Axis. F2 (Machine On) is greyed out all the time. The HAL states look fine from Remora side, thus i'm pretty certain that my issue is with some state/config that is LinuxCNC core. I tried other Frontends like gmoccapy and they behave pretty much the same except that they seem to have some timeout on e-stop blockage and claims that something external is blocking it while axis is keeping at it and never times out, but nothing ever changes even after minutes.
I have endstops configured too, but still tried no_force_homing to ensure its not a problem with endstops.
Some Infos about my setup:HAL Pin States:
iocontrol.0.emc-enable-in = TRUE (from remora.SPI-status) iocontrol.0.user-enable-out = TRUE iocontrol.0.user-request-enable = FALSE (never changes) remora.SPI-status = TRUE remora.SPI-enable = TRUE motion.enable = TRUE motion.motion-enabled = FALSE
HAL Configuration is default remora:
net user-enable-out <= iocontrol.0.user-enable-out => remora.SPI-enable net user-request-enable <= iocontrol.0.user-request-enable => remora.SPI-reset net remora-status <= remora.SPI-status => iocontrol.0.emc-enable-in
INI Configuration:
[TRAJ] JOINTS = 4 NO_FORCE_HOMING = 1 COORDINATES = XYYZ [KINS] JOINTS = 4 KINEMATICS = trivkins coordinates=XYYZ kinstype=BOTH [EMCMOT] SERVO_PERIOD = 5000000 TRAJ_PERIOD = 5000000 BASE_PERIOD = 0 [TASK] TASK = milltask CYCLE_TIME = 0.010
 What is interesting is that noticed on click of e-stop the previously greyed out box of override limits becomes clickable.
Thanks for any help,
Alessandro
8 months 1 week ago #343351 by andrax
I think you have a syntax error.
setp iocontrol.0.emc-enable-in 1
8 months 1 week ago - 8 months 1 week ago #343355 by tuxcnc
  • Code:
    [b]Configuration is default remora:[/b]
  • Code:
    [b][code]net user-enable-out <= iocontrol.0.user-enable-out => remora.SPI-enable
    [/code][/b]
  • Code:
    [b][code]net user-request-enable <= iocontrol.0.user-request-enable => remora.SPI-reset
    [/code][/b]
  • Code:
    [b][code]net remora-status <= remora.SPI-status => iocontrol.0.emc-enable-in
    [/code][/b]
I did it a long time ago and unfortunately I don't remember...
But I think I had the same problem.
My configuration looks like this:
# estop and SPI comms enable and feedback #  net user-enable-out     <= iocontrol.0.user-enable-out          => remora.enable #  net user-request-enable <= iocontrol.0.user-request-enable      => remora.reset #  net remora-status       <= remora.status            => iocontrol.0.emc-enable-in loadrt estop_latch addf estop-latch.0 servo-thread net estop-loopout       iocontrol.0.emc-enable-in  <= estop-latch.0.ok-out net user-enable-out     iocontrol.0.user-enable-out  => remora.enable net estop-loopin        remora.status  => estop-latch.0.ok-in => estop-latch.0.reset net estop-reset         iocontrol.0.user-request-enable => remora.reset net remote-estp         estop-latch.0.fault-in  <= remora.input.12.not
This is Remora via Ethernet, but the differences are probably cosmetic.
Last edit: 8 months 1 week ago by tuxcnc. Reason: Bad formatting
The following user(s) said Thank You: AlessandroEmm
8 months 1 week ago - 8 months 1 week ago #343368 by AlessandroEmm
Thanks Tuxcnc - I tried to replicate this with the SPI-fields of remora-spi. (minus the external pin) Unfortunately the behaviour stays the same. Besides looping in the external e-stop does it do something different in terms of iocontrol states?
image missing https://i.imgur.com/Dt4xAki.png
Last edit: 8 months 1 week ago by AlessandroEmm.
8 months 1 week ago #343372 by AlessandroEmm
Sorry, I dont follow, what Syntax error are you referring to?
8 months 1 week ago #343382 by andrax
You write,
The correct form is
setp iocontrol.0.emc-enable-in = TRUE (from remora.SPI-status)
or
iocontrol.0.emc-enable-in = 1
To pinpoint the error, you would need to provide your configuration.
Time to create page: 0.435 seconds
