Hey guys
I figured it out, as far as I can tell. I didnt put Remora in the title because the states/signals that trigger iocontrol from remora side were, as far as I was able to tell working correctly.
That said all it took was to make it explicit that my linuxcnc instance that it should run with iocontrol v2, which I did by adding
to the EMCIO section. From reading the docs I had assumed that in newer versions of LinuxCNC that it would be the default anyway, hence i never bothered. Also I never had errors.
Now to close this, whats the default today for a standard version of iocontrol in a deb-install of linux-cnc?
Thanks,
Alessandro
