Help needed for conversion of old ( and loved ) Mach3 MPG
- muddiver
16 Aug 2026 08:57 - 17 Aug 2026 17:45 #348789
by muddiver
Help needed for conversion of old ( and loved ) Mach3 MPG was created by muddiver
Hi folks!
i try to get my loved MPG in action in Linuxcnc, but i struggle..
when i ask lsusb i get told its a:[/code]
ID 07c0:0115 Code Mercenaries Hard- und Software GmbH KeyWarrior Combo O Commander
when i ask cat /proc/bus/input/devices i get
[code]I: Bus=0003 Vendor=07c0 Product=0115 Version=0110
N: Name="Code Mercenaries KeyWarrior Combo O Commander"
P: Phys=usb-0000:2a:00.3-3.4.4/input0
S: Sysfs=/devices/pci0000:00/0000:00:08.1/0000:2a:00.3/usb3/3-3/3-3.4/3-3.4.4/3-3.4.4:1.0/0003:07C0:0115.0004/input/input13
U: Uniq=
H: Handlers=sysrq kbd event13 leds
B: PROP=0
B: EV=120013
B: KEY=1000000000007 ff800000000007ff febeffdfffefffff fffffffffffffffe
B: MSC=10
B: LED=1f
P: Phys=usb-0000:2a:00.3-3.4.4/input1
S: Sysfs=/devices/pci0000:00/0000:00:08.1/0000:2a:00.3/usb3/3-3/3-3.4/3-3.4.4/3-3.4.4:1.1/0003:07C0:0115.0005/input/input14
U: Uniq=
H: Handlers=mouse1 event14
B: PROP=0
B: EV=17
B: KEY=70000 0 0 0 0
B: REL=3
B: MSC=10
when i run "halrun" and type in:
loadusr -W hal_input Code Mercenaries KeyWarrior Combo O Commander
The keys get loaded, but they get loaded 5 times!
I am told that the name for the device is "Code Mercenaries KeyWarrior Combo O Commander" ,
but the message also shows 5 times!
What am i doing wrong?
Whats confusing to me too, is that i cannot use
loadusr -W hal_input "Code Mercenaries KeyWarrior Combo O Commander" , that one won't work, only without " , its accepted.
As far as i know, you should always use " when there are blanks in a name / path.
Thanks in advance, Tom
Last edit: 17 Aug 2026 17:45 by muddiver.
- Thank you received: 7496
17 Aug 2026 03:41 #348801
Replied by tommylight on topic Help needed for conversion of old ( and loved ) Mach3 MPG
Try:Whats confusing to me too, is that i cannot use
"loadusr -W hal_input Code Mercenaries KeyWarrior Combo O Commander" , that one won't work, only without " , its accepted.
loadusr -W hal_input "Code Mercenaries KeyWarrior Combo O Commander"Please Log in or Create an account to join the conversation.
- muddiver
17 Aug 2026 17:44 #348818
by muddiver
Replied by muddiver on topic Help needed for conversion of old ( and loved ) Mach3 MPG
Sorry, typo,
this is what i wrote..
At least in halrun this is not going to work.. Am i right that what does not work in halrun will not work in the halfile?
loadusr -W hal_input "Code Mercenaries KeyWarrior Combo O Commander"At least in halrun this is not going to work.. Am i right that what does not work in halrun will not work in the halfile?
- muddiver
17 Aug 2026 18:39 #348820
by muddiver
I do not really understand why,
but when i load the usb-mpg via Vendorkey+Productkey and -K option, all works fine.
Any disadvantages loading the keyboard via vendor/productkey and not via name?
Greets, Tom
Greets, Tom
- muddiver
22 Aug 2026 14:53 #348913
by muddiver
Hi folks,
i tried remapping the keys on my usb-MPG with keyd, but i struggle importing them into the hal.
Is there a prefered way of remapping keys for linuxcnc and do you have a link to a turorial or a manual?
Thanks in advance,
Greets Tom
Thanks in advance,
Greets Tom
- Thank you received: 2177
22 Aug 2026 15:18 #348914
Replied by Aciera on topic Help needed for conversion of old ( and loved ) Mach3 MPG
Do you have the hal_input component working and the pins created?
Maybe show us what you have got and then tell us what is not working. Otherwise we're just guessing.
- muddiver
22 Aug 2026 15:59 - 22 Aug 2026 16:01 #348915
by muddiver
Hi Aciera, nice to meet you!
My Problem is: My USB-MPG sends weird keys, Alt /M , Alt / - , Alt / % , Alt / # , Alt/= , F10 , F11.
Alt / % sends Alt + Shift + 5 , which makes it "interesting" to grab...
F10 and F11 opens the menu and toggles between fullscreen and windowmode.
So, at first i have to somehow keep these keys from interacting with the UI of Linuxcnc, ONLY interacting with hal_input.
I triedi triednone of these stops interacting with my ui..
What i did so far, i grabbed the USB-name, and vendor and productkey of my USB-Davice.
I wrote a UDEV rule which worked after a bit of confusion.
i loaded the device in the halfile ( of the sim so far ) and i could see most of my keys turn yellow in the halshow.
So my first attempt ( asking the AI, which was not my best option when i think about it now ) was to remap the keys with keyd.
I wrote a default.conf to remap the keys. What happened?
The keys which send F10 and F11 do no longer affect ma ui! No toggling window to fullscreen.
But i struggled at importing the "virtual keyd keyboard" into LinuxCNC.I would like to use " , but these don't work for me, i do not know why ( see above )
One of my Problems:
I cannot load the keyboard via "name",does NOT work..works! As far as i know, i should use " whenever i have blanks in a filename / path / device.
I do not really understand why..
Thanks for any help in advance!
Honestly, i tried with AI-support, but this only calmed my mood because our jobs are safe for a looong time, so crappy answers..
Greets, Tom
I tried
[code]loadusr -W hal_input -G Code Mercenaries KeyWarrior Combo O Commanderloadusr -W hal_input -A Code Mercenaries KeyWarrior Combo O CommanderWhat i did so far, i grabbed the USB-name, and vendor and productkey of my USB-Davice.
loadusr -W hal_input virtual keyd keyboarddoesNOT work, "no such device"One of my Problems:
loadusr -W hal_input "Code Mercenaries KeyWarrior Combo O Commander"loadusr -W hal_input Code Mercenaries KeyWarrior Combo O CommanderI do not really understand why..
Greets, Tom
Last edit: 22 Aug 2026 16:01 by muddiver.
22 Aug 2026 18:04 #348920
Not sure I understand you correctly but it you have the pins in your hal reacting to your pendant keys wouldn't you just need to connect those hal pins to the respective pins of your gui?
- muddiver
23 Aug 2026 07:16 #348931
by muddiver
Hi Aciera,
you are right, but i see almost any buttons of my keyboard, i can not figure out how tog et the rest of them.
Another problem is, when i press Button "Z", the menu in LinuxCNC shows up, because "Z" sends "F10" ( or was it F11 ) which brings up the menu. Another Axisbutton toggles between Windowmode and fullscreen of LinuxCNC UI, which is not what i would call a reliable system..
So i think i have to remap the keys send by my keyboard, or is there another solution to this problem i don't know about?
Thanks in advance, Greet, Tom
23 Aug 2026 16:52 - 23 Aug 2026 16:54 #348940
Sounds like you are not acually grabbing the right device.
What GUI are you using? Gmoccapy offers the option to disable keyboard shortcuts.
Last edit: 23 Aug 2026 16:54 by Aciera.
