So no, BOB is not properly isolated for this case.... but 12-24V is also used to power the home, estop and probe inputs on the opposite side of the board.
You should really, really take his advice, and be very careful with wiring.it is safer to use a separate cheap Chinese PWM->0-10V board and a separate small power supply.
Yes, this is a very similar circuit to the one used in BOB and will work identically.this would work, right?
