Meanings of this code
- allenwg2005
- Topic Author
- Thank you received: 4
14 Mar 2019 00:21 #128550
by allenwg2005
Meanings of this code was created by allenwg2005
Could someone please explain what the functional difference between these two blocks of code?
VAR X_POSITION = [X|A|X|1.3]
VAR Y_POSITION = [Y|A|Y|1.3]
VAR X_POSITION = [X|C|X|1.4]
VAR Y_POSITION = [Y|C|Y|1.4]
The A and the C, the 1.3 and the 1.4
Thank you in advance
14 Mar 2019 01:03 #128551
by FariaAl
Replied by FariaAl on topic Meanings of this code
from the Vectric post processor help file:
When output, A=Always | C= Only when Changed.
1.3 output will be to 3 decimal places, this would typically be
suitable for a control that requires metric output.
1.4 If you wished to output the values to
4 decimal places as would be more typical
for a controller operating in inches
hope this helps..
hope this helps..
14 Mar 2019 11:40 #128576
by pl7i92
Replied by pl7i92 on topic Meanings of this code
you may tell us also where the Code Postprocessor comes from
not only the Code itself
- allenwg2005
- Topic Author
14 Mar 2019 13:11 #128580
by allenwg2005
Replied by allenwg2005 on topic Meanings of this code
I'm not sure where I found the post, I was just stumbling around looking at different pp's and noticed the difference and was curious.
I didn't realize the information was in the help manual.
Thanks again
Thanks again
