Positioning for toolchange - var code for Vetric
- allenwg2005
- Topic Author
- Thank you received: 4
15 Mar 2019 17:39 #128673
by allenwg2005
Replied by allenwg2005 on topic Positioning for toolchange - var code for Vetric
You folks have got to be wondering 'what's this clowns problem'!
And you would be right, this couldn't be simpler, you gave me the solution in your replies.
Before going all nuts and assuming I had a lot of study to do on programing my ini I had another look at my PP, the error I was generating when loading my test file into LCNC originated there.
I fixed that, added "TOOL_CHANGE_POSITION = 1 1 0" to my ini, and it works just fine.
One last thing, how and/or where do I program the machine to go to G53 at the end of a file run?
I'm not finding any mention of that in the docs.
- Thank you received: 5928
15 Mar 2019 20:03 #128681
I think i used Vetric once in my life several years ago, so i can not help much.
But i do read everything here, in this forum.
Replied by tommylight on topic Positioning for toolchange - var code for Vetric
No, not by a long shot ! You have to do much better if you plan on looking as a clown!You folks have got to be wondering 'what's this clowns problem'!
15 Mar 2019 20:20 #128684
by bevins
Replied by bevins on topic Positioning for toolchange - var code for Vetric
I use vectric software everyday. I use Aspire for my wood routers.
The post is quite easy, especially for linuxcnc. Version 9 has a linuxcnc post. earlier versions they used an EMC post which will work also. version 9.5 has both.
The manual for their post is pretty good.
at the bottom, Vectric allways sends you to G0 X0 Y0, you can replace that with what you want G53 Xx Yx Zx,
Although I would raise the Z first.
- allenwg2005
- Topic Author
15 Mar 2019 23:06 #128694
by allenwg2005
Thanks for the support folks.
I was just noticing something in my ngc files, I have FEED_RATE, CUT_RATE, and PLUNGE_RATE with the commands [F] [FC] and [FP] to match in my PP, I don't see the plunge rates next to my Z moves. The plunge rate seems to match the FEED speed, so do the CUT RATE speeds. Everything is set to the feed set under 'Feed Rate" in the tool settings.
Did I miss something?
- allenwg2005
- Topic Author
16 Mar 2019 00:04 #128697
by allenwg2005
I think I found the issue, but, (and this is odd), my Feed rate in the tool table is being doubled.
How can that happen?
- allenwg2005
- Topic Author
16 Mar 2019 00:49 #128699
by allenwg2005
I got it, I removed the [F] under RAPID MOVE and it shows nothing now.
And it travels at what I think is the machine rapid speed.
Thanks again.
Thanks again.
Time to create page: 0.078 seconds
