grey1beard is back !
- JohnBr00ker
- Topic Author
17 Apr 2019 23:43 #131089
by JohnBr00ker
Replied by JohnBr00ker on topic grey1beard is back !
I'd just bought a desktop for my workshop system, and already had an up-to-date Mint 19.1 installed, so I'm going ahead with that, even though Im used to Ubuntu.
I edited the line , tar.xz to tar.gx, and it's now moving on.
Fingers crossed !
J
Fingers crossed !
J
17 Apr 2019 23:47 #131091
by alan_3301
Replied by alan_3301 on topic grey1beard is back !
gz not gx, maybe just a typo
- JohnBr00ker
- Topic Author
17 Apr 2019 23:48 - 17 Apr 2019 23:52 #131092
by JohnBr00ker
Looking ahead, I see that the next line ends .patch.gz - perhaps that should also be patch.gx ?
Then on the next instruction to 'Extract and Patch', The same errors ?
J
PS just read your latest post, and I may be 'up the pole' once more !
pps Yes, gz it is
J
pps Yes, gz it is
Last edit: 17 Apr 2019 23:52 by JohnBr00ker.
- JohnBr00ker
- Topic Author
18 Apr 2019 00:05 - 18 Apr 2019 00:06 #131093
by JohnBr00ker
Back at the same place it seems.
Quote
john@john-OptiPlex-GX620:~/rtlinux/linux-4.19.1/linux-4.19.1$ make xconfig
HOSTCC scripts/basic/fixdep
* Could not find Qt via pkg-config.
* Please install either Qt 4.8 or 5.x. and make sure it's in PKG_CONFIG_PATH
scripts/kconfig/Makefile:228: recipe for target 'scripts/kconfig/.qconf-cfg' failed
make[1]: *** [scripts/kconfig/.qconf-cfg] Error 1
Makefile:539: recipe for target 'xconfig' failed
make: *** [xconfig] Error 2
unquote.
Feeling out of my depth, unless I stand on tiptoe !
J
Quote
unquote.
J
Last edit: 18 Apr 2019 00:06 by JohnBr00ker.
- JohnBr00ker
- Topic Author
21 Apr 2019 01:29 - 21 Apr 2019 01:31 #131357
by JohnBr00ker
I tried going through the installation once more, and got further, but still not completed.
Having told terminal to 'make', in building the kernel, it returned the following
john@john-OptiPlex-GX620:~/rtlinux/linux-4.19.1$ make
Makefile:960: "Cannot use CONFIG_STACK_VALIDATION=y, please install libelf-dev, libelf-devel or elfutils-libelf-devel"
HOSTCC scripts/kconfig/conf.o
HOSTLD scripts/kconfig/conf
scripts/kconfig/conf --syncconfig Kconfig
SYSTBL arch/x86/include/generated/asm/syscalls_32.h
SYSHDR arch/x86/include/generated/asm/unistd_32_ia32.h
SYSHDR arch/x86/include/generated/asm/unistd_64_x32.h
SYSTBL arch/x86/include/generated/asm/syscalls_64.h
HYPERCALLS arch/x86/include/generated/asm/xen-hypercalls.h
SYSHDR arch/x86/include/generated/uapi/asm/unistd_32.h
SYSHDR arch/x86/include/generated/uapi/asm/unistd_64.h
SYSHDR arch/x86/include/generated/uapi/asm/unistd_x32.h
HOSTCC arch/x86/tools/relocs_32.o
HOSTCC arch/x86/tools/relocs_64.o
HOSTCC arch/x86/tools/relocs_common.o
HOSTLD arch/x86/tools/relocs
UPD include/config/kernel.release
WRAP arch/x86/include/generated/uapi/asm/bpf_perf_event.h
WRAP arch/x86/include/generated/uapi/asm/poll.h
WRAP arch/x86/include/generated/asm/dma-contiguous.h
WRAP arch/x86/include/generated/asm/early_ioremap.h
WRAP arch/x86/include/generated/asm/export.h
WRAP arch/x86/include/generated/asm/mcs_spinlock.h
WRAP arch/x86/include/generated/asm/mm-arch-hooks.h
UPD include/generated/uapi/linux/version.h
"4.19.1-rt3-rt3--- localversion-rt +++ localversion-rt @@ -0,0 +1 @@ +-rt3" exceeds 64 characters
Makefile:1145: recipe for target 'include/generated/utsrelease.h' failed
make: *** [include/generated/utsrelease.h] Error 1
unquote
I'm quite prepared to have another attempt, but should I somehow remove/purge my earlier attempts, and if so, how?
Thanks,
unquote
Thanks,
Last edit: 21 Apr 2019 01:31 by JohnBr00ker.
- Thank you received: 5923
21 Apr 2019 02:04 #131361
Replied by tommylight on topic grey1beard is back !
On a fresh install of LinuxMint 19.1
download and install by double clicking ( use gdebi ) for 64 bit
simosnet.com/debian/packages/Konalinux/d...t5-kona-rt_amd64.deb
and
Install Grub Customizer as per guides from JT or the other ones, reboot to that kernel.
Download the stretch or precise version of Linuxcnc from the buildbot
buildbot.linuxcnc.org/~buildmaster/dists/
I do not remember the exact version i used, but since they are all small files just download one and try to install it, gdebi will tell you if it can or can not install so try the other, one of them will tell you that it just needs to download some other packages and it does that automatically.
That should do the trick.
and
- JohnBr00ker
- Topic Author
21 Apr 2019 02:25 #131363
by JohnBr00ker
Many thanks. I'll give that a try tomorrow.
Time to create page: 0.090 seconds
