Dismantling a China C5 Ballscrew and giving it a C7
13 Apr 2019 11:25 #130764
by pl7i92
Dismantling a China C5 Ballscrew and giving it a C7 was created by pl7i92
I did face the problem on changing the Nut Direction on a China C5 SUF2005
as i needed the 8mm of extra space for the Toolchanger
so i did what all people say don't DO THIS avoid under any surcomstances
As well as they where sealed without screws !
and the seals where so tight to not fitting the loosen PIPE 15.25inside and 18mm outside into it to keep balls inside
THEN I gone the HARD way take a CAN(empty) and screw it out over the CAN let the BALLS faling out HEARTBEAT Moment
"ONLY" 30 balls cam out and they where in the roundtrip nut only in the first and last turn
THE Ballscrew nut hat the 3 inlays for 3 Round trip loops but no balls in there
the mesurment of all bals came up to 3.12-3,16 mm
Where 1/8" is 3.175
The Shop DIN Suply and Tusnelda Bianca Zündorf got 50 StealBalls for 2Euros
Now the Assamply to a C7 folowing this video
68Balls now in
The seal where now without function only to keep dirt away while in C5 mode they where
and finally it did Run more Smooth much faster and more precise i feel
it is realy a challenge and work but the aftermath is given me that match Benefit as i will do all other Ballscews as well
Where 1/8" is 3.175
68Balls now in
13 Apr 2019 14:50 #130773
by OT-CNC
Replied by OT-CNC on topic Dismantling a China C5 Ballscrew and giving it a C7
Re-balling will not increase the accuracy of your ball screw. What you are suggesting is to reduce the backlash. Your lead accuracy will remain.
You probably want to remove the seals before inserting the ball retaining tube or risk the chance of losing some balls when threading the screw out. (The red tube shown in that video towards the end) That tube is key item for anyone trying to do this for the 1st time. During assembly I found it's pretty likely to dislodge a ball. Tube helps keeping them in place.
Sometimes you can stand the screw and nut up vertically and fill the ball race while rotating.
- Thank you received: 5874
14 Apr 2019 00:25 #130805
Replied by tommylight on topic Dismantling a China C5 Ballscrew and giving it a C7
Ohhhhh i have done that many times, to the point that it takes me about 3 minutes to have it done, but those where NSK 2505 and 4010 ! Have to do another one, chinese 2505 and it has much smaller balls than the NSK.
14 Apr 2019 08:47 #130837
by pl7i92
Replied by pl7i92 on topic Dismantling a China C5 Ballscrew and giving it a C7
Thanks for the advice
@ tom
balls are available in standard sizes all over
but they are not what the china guys use
seams that they sell only the fit as C5 C7 displace what is inside
meaning the Roller puts out lets say 200m per Set of roles
50meter C7 and 120m C5 the rest is not sold its for CNC production ready made mashines
as you can buy a 6040 asamplyes in CN for less then 400USD
@ tom
14 Apr 2019 12:18 #130845
by Leon82
Replied by Leon82 on topic Dismantling a China C5 Ballscrew and giving it a C7
The screw tolerance is error over 300 mm or 12 inch.
15 Apr 2019 06:42 #130891
by pl7i92
i simply cand belive that 30 balls over less then 2 turns make the same as
68bals over 3full turns
as well as there where undersised
the 3,175 3.16-3,17 mutch more precise new balls
if you tell me thats the case i will test this on 3mm precice balls so more airspace better run
- Thank you received: 1369
15 Apr 2019 13:34 #130903
Replied by Todd Zuercher on topic Dismantling a China C5 Ballscrew and giving it a C7
In a ball screw it is very normal to have half under-sized balls. The small balls work as spacers between the larger loaded ones doing the work, serving the same purpose as the bearing cage in an ordinary bearing.
Time to create page: 0.119 seconds
