mid2cnc.py how to
  • Dinuka_Shehan
  • Dinuka_Shehan's Avatar Topic Author
  • Platinum Member
  • Platinum Member
27 Sep 2019 21:40 #146435 by Dinuka_Shehan
mid2cnc.py how to was created by Dinuka_Shehan
I want to find mid2cnc.py.
I Google it but not found.
Have you knew about before.from where can i find it.
If there anyone experienced with it please guide me through.
Thank you
28 Sep 2019 05:38 #146452 by nkp
The following user(s) said Thank You: Dinuka_Shehan
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
28 Sep 2019 07:16 #146455 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic mid2cnc.py how to
Lot of thanks.
Any guild lines or tutorial for this.
28 Sep 2019 07:30 #146461 by pl7i92
Replied by pl7i92 on topic mid2cnc.py how to
is there a real need to play music on gcode behavior
you can simply ad a Light or a 1USD electronic that rings on finish / error / somthing you may get info
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
28 Sep 2019 10:49 #146483 by Dinuka_Shehan
No my deutsch friend.
Cnc is a way of life.
We have to do everything we could.
Otherwise it is not satisfied with myself.
Everyone is different.
We have to think wise as well as we think differently.
That makes the world beautiful.
Kannst du verstehen
The following user(s) said Thank You: MaHa
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
28 Sep 2019 10:51 #146484 by Dinuka_Shehan
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
28 Sep 2019 11:39 #146485 by Dinuka_Shehan
How to execute this codes
  • Moderator
  • Moderator
28 Sep 2019 11:56 #146486 by tommylight
Replied by tommylight on topic mid2cnc.py how to
in a terminal
python mid2cnc.py
enter
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
28 Sep 2019 12:06 #146487 by Dinuka_Shehan
Then how to add custom midi file.
I want to my own file.
not understand that how to do it correctly.
Help please
  • Moderator
  • Moderator
28 Sep 2019 12:14 #146488 by tommylight
do not know, never used it.
Time to create page: 0.207 seconds
