- Other Stuff
- Off Topic and Test Posts
- For plotter - which category to discuss please (Plasma cutters ?)
04 Dec 2019 18:50 #152015
by Mayiladan
Hi all, nice to find the community
I am trying to see if i can run a RedSail RS720C vinyl plotter-cutter in LinuxCNC.
I am supposed to post the doubts and results in PlasmaCutters category right ?
Hoping to spend some nice times here !
- Thank you received: 1230
04 Dec 2019 19:44 #152018
Replied by tommylight on topic For plotter - which category to discuss please (Plasma cutters ?)
What type of connector does it use to communicate with the PC ?
The following user(s) said Thank You: Mayiladan
- Platinum Boarder
- Thank you received: 771
04 Dec 2019 20:47 - 04 Dec 2019 20:49 #152020
Replied by Todd Zuercher on topic For plotter - which category to discuss please (Plasma cutters ?)
I know I've seen posts on the forum referring to questions about setting up a drag knife cutter before. (You may need to search further back in time than the site's default of 1 year.) As to the success of those individuals final results I can not say.
I'm sure at the lowest level Linuxcnc could control that machine. But you could run into issues trying to interface with existing hardware depending on what it is.
Last edit: 04 Dec 2019 20:49 by Todd Zuercher.
05 Dec 2019 14:16 #152067
Replied by andypugh on topic For plotter - which category to discuss please (Plasma cutters ?)
I think that Gcodetools for Inkscape can output an angle for a rotating knife.
I guess a true drag-knife will self-orient, within limits.
05 Dec 2019 20:12 #152095
by Mayiladan
Replied by Mayiladan on topic For plotter - which category to discuss please (Plasma cutters ?)
hi all
Yes, its a drag-Knife cutter.
It has both USB and RS232 connector.
I will try to find out the motherboard, chip and motor details too.
Will be updating the progress here..
- Other Stuff
Time to create page: 0.078 seconds
