Is Arduino have Good Future?
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
11 Sep 2020 11:37 - 11 Sep 2020 11:38 #181748 by BeagleBrainz
Replied by BeagleBrainz on topic Is Arduino have Good Future?
I’ve seen it and almost had a so called doctor puncture my femoral artery by manipulating my femur which had been shattered into many pieces.
It wasn’t till I was on the table the next day that my heart stopped.
But the nurses are worth more than their weight in gold.
Last edit: 11 Sep 2020 11:38 by BeagleBrainz.
11 Sep 2020 12:24 #181752 by Mike_Eitel
Replied by Mike_Eitel on topic Is Arduino have Good Future?
@Aciera
Where in Switzerland are you.
Greatings from 8224 Löhningen
Mike
11 Sep 2020 12:29 #181754 by Aciera
Replied by Aciera on topic Is Arduino have Good Future?
Greetings Mike
So you're from the far north. I'm from Baar ZG.
cheers
11 Sep 2020 12:39 #181755 by Mike_Eitel
Sometimes I visit a supplier in Cham..
We are living in a not so small world.. ;-)
Mike
11 Sep 2020 12:47 #181756 by Aciera
You should come by for a coffee next time.
12 Sep 2020 10:09 #181865 by Mike_Eitel
Will keep 5hat in mind ;-)
Same if you might be around sometime.
Mike
15 Sep 2020 12:03 #182217 by shadab
Replied by shadab on topic Is Arduino have Good Future?
I always discourage people from using Arduino early on in their careers because it is my perception that Arduino makes people lazy. You can find a library for just about anything you want to do with their boards. For doing DIY projects and people who are not professional embedded developers but just want to make something work, its okay. If you want to really learn embedded systems look elsewhere.
The following user(s) said Thank You: BeagleBrainz
16 Sep 2020 08:55 - 16 Sep 2020 09:08 #182410 by Himarc3D
Replied by Himarc3D on topic Is Arduino have Good Future?
Arduino was made for rapid prototyping, thats the beautiful of the library’s you can know pretty fast if your idea work, if your design work you need to cut cost searching components for your design.
Even if you make large scale you cant make money using the arduino board in your product.
At begin i did the mistake to put Arduino Mega inside one leak test machine (at time I didn’t know about PLC stuff) the time I spend to make all protection (industry) don’t compensate at all even if i make 100 in china its more cheap buy one PLC.
One example because covid, you can make one elevator panel that dont need touch but use celular to select the floor using Arduino, test it inside the build for signal (touch the elavator panel here in Japan you loose the maintenance contract) if you have all workng in the cellphone part you can show it to some company, here Fujitec implemented this fir their elevators.
Time is money.
Last edit: 16 Sep 2020 09:08 by Himarc3D.
16 Sep 2020 09:09 #182413 by shadab
Because of arduino the prices of ATMEL AVR chips have inflated a lot. For example an ATMEGA 328p chip used in Arduino Uno(which is the most popular Arduino Board) is way more over priced than the later upgraded versions of the same chip.
Quick search on mouser:
ATMEGA328p: ₹151.84 (~2$)
ATMEGA808 : ₹56.94 (<1$)
ATMEGA808 is better than ATMEGA328 in every way, but we have to pay the 'Arduino tax' for the latter chip.
16 Sep 2020 09:13 #182415 by Himarc3D
i dont get your point?
Time to create page: 0.712 seconds
