Feeding Gcode from a streaming server (with buffer)
- PlasPak
07 Mar 2021 03:43 - 07 Mar 2021 05:04 #201268
by PlasPak
Feeding Gcode from a streaming server (with buffer) was created by PlasPak
Hi All, I'm trying to feed Gcode to LinuxCNC via a streaming server (using a Python Script).
I got it working but I get a bunch of errors that one doesn't get when loading the Gcdoe the traditional way. So far, the same error happens regardless if the file is local or from the web.
Here's a test: vimeo.com/520316807
Is anyone interested in testing the code and giving us feedback?
Last edit: 07 Mar 2021 05:04 by PlasPak.
07 Mar 2021 13:10 #201330
Replied by andypugh on topic Feeding Gcode from a streaming server (with buffer)
DNC used to be used in the days of very limited controller memory.
What is the reason for using it here?
- Thank you received: 7504
07 Mar 2021 15:05 #201357
Replied by tommylight on topic Feeding Gcode from a streaming server (with buffer)
The only reason for that i can think of is if that gcode needs to be generated by some other sensor/s, and even then using external offsets might be a better solution.
- PlasPak
08 Mar 2021 03:21 #201402
by PlasPak
Replied by PlasPak on topic Feeding Gcode from a streaming server (with buffer)
Here's the Python script:
(and the test Gcode attached)
import boto3
import importlib
import os
import sys
import linuxcnc
MODES = {
linuxcnc.MODE_MANUAL: 'MANUAL',
linuxcnc.MODE_AUTO : 'AUTO',
linuxcnc.MODE_MDI : 'MDI'
s=linuxcnc.stat()
c=linuxcnc.command()
def print_mode():
s.poll()
print "Current MODE: ", MODES[s.task_mode]
sqs_client = boto3.client(
'sqs',
region_name='eu-central-1',
aws_access_key_id='AKIAS5AWEKP2OBREGAQW',
aws_secret_access_key='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'
s3_client = boto3.client(
's3',
print("Retrieving orders...\n")
response = sqs_client.receive_message(
QueueUrl='https://sqs.eu-central-1.amazonaws.com/199762400244/devmssn',
AttributeNames=[
'All',
MessageAttributeNames=[
'All',
MaxNumberOfMessages=10,
VisibilityTimeout=5,
WaitTimeSeconds=20,
def ok_for_mdi():
c.mode(linuxcnc.MODE_MDI)
s.poll()
return not s.estop and s.enabled and (s.homed.count(1) == s.axes) and (s.interp_state == linuxcnc.INTERP_IDLE)
for message in response['Messages']:
print("Order ID:"+message['MessageAttributes']['Order']['StringValue']+"\n")
print("GCODE file name: "+message['Body']+"\n")
s3_client.download_file('devmssn', 'orders/'+message['MessageAttributes']['Order']['StringValue']+'/'+message['Body'], message['Body'])
print("GCODE downloaded...\n")
f = open(message['Body'], "r")
while 1:
gcode_line=f.readline()
#print(gcode_line)
if gcode_line == '':
break
if ok_for_mdi():
c.mdi(gcode_line)
c.wait_complete()
r=sqs_client.delete_message(
ReceiptHandle=message['ReceiptHandle']
08 Mar 2021 09:31 #201437
So, what is the error?
- udoS
- Thank you received: 25
22 Sep 2021 05:38 - 22 Sep 2021 05:38 #221333
by udoS
Replied by udoS on topic Feeding Gcode from a streaming server (with buffer)
@andypugh
is this topic still open ?
I'm reading position value of parts with opencv.
Where to send this values into Lcnc to go and pic the part.
I can get the value into hal but then where do I connect them.
best rgds. udo
best rgds. udo
Last edit: 22 Sep 2021 05:38 by udoS.
Time to create page: 0.850 seconds
