Automatic Rebar bending machine
5 years 3 months ago #216368 by shpatb
Hello , i hope You are all doing well .A guy showed at my workshop and asked me if I could build an automatic bending machine for steel rods for appliance in construction sites .Machine should look something like this :
I was wondering if anyone here has any kind of experience with this stuff to exchange any ideas for parts that are needed to build this kind of machine.
Kind regards
Shpat
5 years 3 months ago #216491 by andypugh
It looks like a relatively simple 3-axis machine.
It should be pretty easy to control with LinuxCNC, though I imagine that the G-code would need to be hand-coded.
I think that the rotating bend axis needs to be a true axis, then it can make other angles than 90 degrees and could also be used to make gentle curves (if the linear axis is strong enough)
More ideas (such as 3D bending here:
The following user(s) said Thank You: shpatb
5 years 3 months ago - 5 years 3 months ago #216512 by shpatb
Thanks for reply Andy.
the bending axis should be build with servomotor with reduction , or an electromotor controlled by timer. (eg, wait 3 seconds and rotate the shaft for the product size as desired )
thanks Shpat.
Last edit: 5 years 3 months ago by shpatb.
5 years 3 months ago #216623 by andypugh
I would use a servo motor with reduction so that the bender position was controlled closed-loop as a G-code axis.
5 years 2 months ago #216701 by shpatb
cool , thanks for Ur time!
4 years 7 months ago #238864 by jane song
We provide a variety of steel bar bending machines, small rebar bending machine and CNC stirrup bar bending machine. The price is very cheap, if you are interested, you can visit rebarequip.com/cnc-bender-machine
Time to create page: 0.294 seconds
