Automatic Rebar bending machine
4 years 7 months ago #238887 by tommylight
The above post is considered spam, but it is about the topic and the web site seems ok, so leaving it for now.
4 years 2 months ago #250878 by valts
I have stirrup bender and thinking to retrofit it on Linuxcnc. So ,if You need information about gear ratio and design . First , what is max wire diameters will be used.
4 years 1 month ago #251558 by shpatb
Hello,
From 6mm diameter to 12 mm maximum .
4 years 1 month ago #251747 by valts
Hi
Bending and wire pulling motor is 3 kw servo 3000rpm, 14,3Nm, gearbox I=21,62
The following user(s) said Thank You: shpatb
Time to create page: 0.384 seconds
