- Thank you received: 62
I would use a servo motor with reduction so that the bender position was controlled closed-loop as a G-code axis.Thanks for reply Andy.
the bending axis should be build with servomotor with reduction , or an electromotor controlled by timer. (eg, wait 3 seconds and rotate the shaft for the product size as desired )
