Electrical cabinet cooling
- my1987toyota
- Thank you received: 447
they never leak. That would also come with a drawback of needing a circulating pump plus fans to move air over the
radiator cores. That said it is also possible to use a trans. cooler in the cabinet and a 55 gallon drum full of water outside the
garage as the cooling medium and do evaporative type liquid cooling . I would have to worry about mosquitoes though.
I do live in Florida after all.
- spumco
- Thank you received: 905
A couple of big surplus heatsinks bolted back-to back through the enclosure top or wall seems less fussy.
- my1987toyota
I just wish the aluminum heat sinks were cheaper . Why is it that a radiator being more complex, more labor intensivespumco post=224724 userid=28776I have an alergic reaction to conductive liquids inside electrical enclosures. I know, I know... liquid cooled PC and all that, but still...
to build, cheaper then an extruded aluminum heat sink. Rhetorical question obviously. And I hear you on the conductive fluids thing .
That's why I want to go with an air to air inter-cooler instead. I had dismissed the air to liquid thing a little bit back . I put it down
on a previous post as one of the possibilities I had no intension of doing it.
- spumco
A 8"x18"x0.5" fine-pitch extruded heat sink is about $30.
$60 for a passive radiator and no fussing around? Come on now...
- my1987toyota
Not sure why I haven't seen them before But I will be checking them out . Because YES that is reasonable pricing.HeatsinksUSA.
- spumco
They should work fine, keeping the enclosure internal temps up a bit to help with humidity and condensation, but as the temp differential climbs they'll start doing their job. Worst case, you add a cheapo 120mm case fan on the outside just to stir things up a bit.
Note - if you're going back-to-back, sand them flat on a surface plate or run a flycutter across the back. The ones I got from them were very nice, but not flat enough for good heat transfer.
- my1987toyota
I intended to use a fan of some sort 1 inside and 1 outside of the case. Thanks for the heads up on the base surface.Glad to put you on to them. Just pay attention to the spacing and fin height. I wound up having to fiddle around a bit to get some screws down in there... i.e. plunging with a 3/8 end mill just to get some clearance.
Fortunately I have access to a large surface plate at work. I also intend to use Thermal transfer grease to make sure
I have a good heat path.
- Thank you received: 7476
Almost all VFD's and new servo drives have the mounting alu plate, so just bolting them to a big heatsink with fins outside should do much better than 2 heatsinks with no physical contact to equipment.
- Thank you received: 4654
Transmission coolers are air-to-oil, though. An air-to-air intercooler sounds like it might be very suitable, as the orifices are an appropriate size for a circulating fan.That would work but perhaps consider a transmission cooler as they are a lot smaller.
Something like this could be very readily bolted to the outside of a cabinet: www.amazon.co.uk/Intercooler-Toyota-3S-G...resize/dp/B08LQRY4RD (and would retain the Toyota theming :-)
- my1987toyota
