laser cutting double sided pcbs
30 Jun 2022 15:24 #246304 by robertspark
laser cutting double sided pcbs was created by robertspark
I put this in off topic as it is not linuxcnc in content but for those who may be into prototyping PCBs
www.google.com/amp/s/www.instructables.c...ter/%3famp_page=true
The following user(s) said Thank You: tommylight, my1987toyota
  • Moderator
  • Moderator
30 Jun 2022 15:51 #246311 by tommylight
Replied by tommylight on topic laser cutting double sided pcbs
You started it ! :)
The following user(s) said Thank You: my1987toyota
12 Jul 2022 05:52 #247130 by my1987toyota
Replied by my1987toyota on topic laser cutting double sided pcbs
Interesting concepts . They would need some refinement to make them more practical. I can see via's and through
hole plating being a problem. That said there are ways around that. For one off got to have it that day I guess it
would work.. Call me a snob but I will stick with a fab house. Otherwise its perf-board and wire wrap or milled copper clad.
16 Jul 2022 06:38 #247451 by andypugh
Replied by andypugh on topic laser cutting double sided pcbs
Have you seen VeroWire?
www.instructables.com/PCB-Prototyping-With-Verowire/
16 Jul 2022 07:50 #247456 by my1987toyota
that is definitely an interesting concept. I may give it a try someday.
